Sponsored by:
Sponsored by:
Tighten Crankshaft Pully Bolt.
Old 01-04-2015, 12:10 AM
crw's Avatar
crw
crw is offline
Default Tighten Crankshaft Pully Bolt.
I have a 92 accord with a 5 speed manual transmission. How do you tighten the crankshaft pulley bolt without the engine turning? According to the haynes manual the torque spec is 160 lbs and I want to tighten this to the right spec without just using an impact wrench and hoping its good enough.
Thanks,
CRW
Old 01-04-2015, 06:25 AM
There is a "holder socket" for the pulley. You will need that tool to be able to hold the pulley as you tighten the bolt.
Old 01-04-2015, 09:59 AM
W/ a manual trans you can place the engine in 1st gear, set the ebrake and/or get someone to hold footbrake while you tighten the crankshaft pulley w/ a torque wrench.
Note, most inexpensive torque wrenches can only be set to 150 ft-lbs maximum. For that reason I have always estimated the final torque (using lever arm length times estimated force) to set final torque.
fhorta
08-17-2012 07:26 AM
vman858
06-23-2008 12:14 PM
FLHonda98
03-02-2007 07:13 PM
RoKnAzn
01-05-2007 02:27 AM
laffinfish
12-27-2006 06:12 PM
Quick Reply: Tighten Crankshaft Pully Bolt.
