1990 Accord Radiator
Old 01-19-2007, 09:36 AM
gimme789's Avatar
Default 1990 Accord Radiator
How difficult is it to replace a radiator on a 1990 Accord 5 Speed 4 Dr LX 2.2 ? I've never done one, however, the task does not intimidate me. How much would you expect a local garage mechanic to charge ? ( not the dealer ... I know how much they want $$$$$$$$$$$$) thanks Tom
Old 01-19-2007, 11:26 AM
deserthonda's Avatar
Default RE: 1990 Accord Radiator
u go to our DIY section there is a write up on how to replace the radiator, rwad it and see if it is something you may want to do
a shop might charge you 1.5 to 2 hrs in labor , depending on the labor rate that is what you would pay for labor,, radiator you can gat one for around 100-120 dollars
Old 01-20-2007, 02:59 PM
gimme789's Avatar
thanks - that is a nice write up .. I may try it (thanks)
My local mechanic suggested trying an off the shelf Radiator Stop Leak product.
Does anyone have any preferred brands I should try ? Or any reasons why maybe I shouldn't ?
The leak is small ... I think this may be a good solution (at least temporarily anyhow)
Thanks!
Old 01-20-2007, 05:34 PM
drummer1279's Avatar
if you have a leak go ahead and replace the radiator, because stop leak is only temporary not only that most of them will gum up the rest of the cooling system as well leaving you with a messy flush job when you eventually replace the radiator anyway. Go ahead and replace the radiator and be done.
Old 01-20-2007, 11:26 PM
hondadude's Avatar
ORIGINAL: gimme789
Thanks!
Sounds like a great idea until the heater core gets plugged up; I've seen this too many times.
If the radiator needs replaced "just do it"
Old 01-21-2007, 03:23 AM
I agree with Dude,,,,,,,,stay away from the stop leak crap...........if radiator leaks replace it
doomx3
08-09-2015 10:53 PM
BigRoach
06-03-2013 01:54 PM
Novaknowledgenow
05-30-2013 08:58 PM
hmr
03-28-2012 10:49 PM
mjhenks
02-11-2010 07:40 AM
Quick Reply: 1990 Accord Radiator
