Sponsored by:
Sponsored by:
Tire Speed Rating rules
Old 06-04-2007, 02:09 AM
kaiotes's Avatar
Default Tire Speed Rating rules
i have a 98 accord v6 coupe, would like to know if i need to stick w/ the recommended V rating for my tires or i can go use a T rated tire. Currently i've driven 45k+ on a set of H rated pepboys touring tires w/o much problem, but they were a lil noisy on the freeway. It's time to replace them and i would like to know if the speed rating is critical to the overall performance of my vehicle. I rarely drive 90mph; mainly 70...
any suggestions would be greatly appreciated
Old 06-04-2007, 03:56 AM
Default RE: Tire Speed Rating rules
You will be good with even standard S rated tires. As long as you dont regularly haul BUTT
Old 06-04-2007, 10:02 AM
YeuEmMaiMai's Avatar
speed ratings
Q- Up to 100mph
R- Up to 106mph
S- Up to 112mph
T- Up to 118mph
U- Up to 124mph
H- Up to 130mph
V- Up to 149mph
W- Up to 168mph
Y- Up to 186mph
Z- 149mph and
with a V6 accord do you REALLY want to get cheap on the speed rating H would be as low as I would go... GY Eagle GT-R with 50K warranty start @ 76 a tire at discount tire
Old 06-04-2007, 10:24 AM
kaiotes's Avatar
what do you mean by Haul BUTT
is it ok or not?
I don't see the goodyear tires mentioned, cheapst goodyr i see is the Goodyear Eagle GT-HR for 90
Old 06-04-2007, 11:31 AM
It's not always absolutely true, but generally the lower speed ratings have softer sidewalls, so they mightfeel a bit mushier.
If the car is CAPABLE of exceeding 130mph, some tire shops will be afraid of liability if they install lower-rated tires. They have to trust you about not driving that fast.
Old 06-04-2007, 08:39 PM
It's ok to use lower rated tires. Just atleast get a good brand. Michelins r good.
Old 06-04-2007, 10:23 PM
Just dont go below the speed rateing that your original tires were rated at...
Old 06-04-2007, 11:20 PM
accord4sroy's Avatar
i saw always go with the recommended speed rating for your vehicle. i remember honda had yokohama's with a t rating and i didn't buy it for them i was all set and ready to buy it from them. i went to sam's club and bought some good bf goodrich traction ta's. also, these tires i got can carry a little bit more weight with the load index being at the 91 rating instead of 89 (p195/65/89H) is what tire size is recommended for my vehicle. i miss the michelin's that were originally on there. had dunlop sports put on there which didn't last long, but am satisfied with the traction ta's. good luck for your search for the right tire!
Old 06-05-2007, 10:48 AM
RTexasF's Avatar
Super Member
I'm in agreement to stick with the speed rating that came originally on the car. I have noticed thoughthat the online tire stores all offer H rated tires for the cars that came with V's and have no qualms about selling them. Due to the H's being less $$ I wonder if it's really a bad thing to step down a notch. I would not go below H under any circumstances, T is just too low on the scale.
Old 06-05-2007, 11:48 AM
T is definitely too low on the scale for a H-rated original tire for a car. I am pretty sure you might not have the same handling when you step down to a lower rated tire.
Quick Reply: Tire Speed Rating rules
