Transmission delay in shifting
Is D4 light blinking? If yes, see DIY forum for instructions on determining code. Even if light is not blinking some code/s may be stored.
Flaring at shift is a sign of aging that generally can't be fixed w/o trans overhaul. However it usually affects 1-2 shift first.
Are you using Honda ATF? If not, suggest several drain/refill/run cycles to replace w/ Honda ATF.
Check the AT throttle control cable. Throttle control lever should begin to move at same time as engine idle increases. Adjust locknuts to change throttle control cable setting.
