transmission fluid change recommendations?
Only use Honda ATF. My 90 accord EX takes 2 1/2 qts for a simple drain and fill. Do not overfill. Put in 2 1/2 qts then roadtest. Check the level after the engine shutdown and fluid is at normal operating temperature.
A good way to measure the drained fluid is to drain it into a calibrated milk jug. Mine is marked off at 2 1/2, 3 and 3 1/2 qts. This will tell you how much fluid actually drained.
93Accord2.2
12-17-2021 09:59 AM
62maxx
10-18-2015 08:20 AM
93Accord2.2
01-20-2012 01:02 PM
