Screeching drivers window
Old 11-07-2012, 10:47 AM
fiend's Avatar
Default Screeching drivers window
My drivers side window produces an extremely loud screeching sound when lowered. The car is a 97 Honda Accord SE, with power windows.
Any help on stopping the screeching sound is much appreciated.
Old 11-07-2012, 11:48 AM
The outer window seal (horizontal along the lower window opening) rubs against the window as window goes up/down. Going up seal is pulled open, however going down it may "chatter" since it's being pushed by friction. W/ age the seal becomes very stiff, increasing liklihood of skip/chatter producing a noise. You should be able to see this happening, if this is cause.
There could also be a problem w/ the window regulator, perhaps needing lube on the scissor-type joints. You would need to remove the door panel to access regulator.
Ultimately you might need to remove the window and regulator to properly lubricate. Access through door inner openings is limited.
If regulator is problem, I would replace the regulator. Replacements are available at reasonable prices. Check ebay, amazon, rockauto, etc.
Old 11-07-2012, 02:50 PM
fiend's Avatar
Thank you for the reply.
Would a silicone spray from Advanced auto parts be suitable for lubrication?
Old 11-07-2012, 06:45 PM
If problem is the external window seal, then silicone spray may offer some temporary relief. A new seal is required for permanent fix.
Michael Bomes
09-09-2012 03:12 PM
vmysore
08-08-2008 09:25 AM
confuseid
03-12-2008 08:13 AM
dragoneyes
06-26-2007 09:51 PM
trukid21
03-06-2007 10:08 PM
Quick Reply: Screeching drivers window
