front cowl removal, 7th gen
Help!! I am replacing my front wheel bearing on my 2004 Accord 4-door EX
5-sp, and am 80% finished. But, the ABS sensor wire needs to be routed in the right side fender well. In order to gain clearance to connect the 2 ends of the connectors, I need to remove the pass side strut brace from the fire wall. And in order to do this I need to remove the cowl at the base of the W/S. I can’t find the thread/directions how to remove it. If you can send me the link, I can finish this and would be so happy.
nukestar88
02-28-2011 10:20 PM
