Turn key and nothing happens - Honda Accord Forum - Honda Accord Enthusiast Forums
Reply
LinkBack Thread Tools Search this Thread
Old 02-08-2011, 07:15 PM
Default Turn key and nothing happens
Today when I got in my accord I out the key in the ignition and nothing happen, no lights, no dash, no turn over. I tok the key out and waited a few minutes and it started back up no problem. I figured it was just a fluke so I let it go until it happened again later in the afternoon. This time I tried many times before the care finally lit up and turned over. Any thoughts?
Old 02-08-2011, 07:22 PM
Can we at least know the year of the car? The more information the better.
Without that...check, clean and tighten all of the battery connections.
Old 02-08-2011, 07:46 PM
Sorry. 2004 Accord Lx two door. Less than 50,000 miles. Never had a problem until today other than battery replacement in the fall. checked the battery when it happened this morning.
Old 02-08-2011, 09:38 PM
Ok, sorry for sounding blunt...I'm still with double checking the connections. Can you give more details to "checked the battery when it happened this morning". If the battery is good, voltage at the starter (big cable and the small one) are good then I'd go with the starter. So, check the voltage on those two...if you have power to the starter (both cables) and nothing happens, pull it, have it tested and replace if bad.
Old 02-09-2011, 02:09 AM
Youll also want to look for leaking fuel injectors, Faulty fuel pump where the fuel is not getting up to the fuel rail fast enuff, Fuel pump relay not working..I could go on and on..You need to get it started and then taken and have those thing tested.
Old 02-09-2011, 07:59 AM
No need for appologies. Goingto check some things this morning.
Reply
Thread Thread Starter Forum Replies Last Post
Key + Key Fob Conversion to a Flip Key csh217 General Tech Help 2 06-17-2014 06:53 PM
turn key nothing happends after belt replacement osomex General Tech Help 5 02-01-2012 08:30 AM
car wont start, turn key and nothing happens. turnbacknow General Tech Help 8 11-17-2010 01:20 PM
what happens if i "pedal to the floor" on ice with my 1997 A/T accord??? miks Suspension 3 09-22-2007 08:42 AM
Fan Running - Now happens more often Turkey General Tech Help 10 07-18-2006 05:39 PM
Tags
2004, 88, 94, accord, battery, card, dash, door, honda, key, lights, lxi, m1710, preplacement, turn, vid
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
