Sponsored by:
Sponsored by:
URGENT HELP NEEDED - KEYS LOST
Old 06-10-2007, 08:12 PM
aqbui
Default URGENT HELP NEEDED - KEYS LOST
I have an 06 accord lx and I accidently threw my keys down the trash shoot. I live in an apartment complex so I am worried that someone found them. Is there any way to temporarily disable my keyless entry? Is there a way to permantly disable it? If I go to my dealer will I be able to get my car reprogrammed? If I can is it expensive? Do you guys have any other suggestions?
Old 06-11-2007, 09:04 AM
Default RE: URGENT HELP NEEDED - KEYS LOST
Check this thread... I think it'll work for 2006.
https://www.hondaaccordforum.com/m_45857/tm.htm
That will make it so ONLY the keys you use in step 7 will work for keyless entry. If you dig thru the garbage & find your key, you can do that procedure over again to reinstate that key.
A dealer or sometimes a locksmith or independant Honda repair shop can use their scan tool to perform a similar procedure for the immobilizer. That will prevent the lost key from starting the engine.
The only way to prevent the lost key from opening the door is to re-key all the locks.
Old 06-12-2007, 07:59 PM
aqbui
bump
thanks for the reply, I'll be sure to try it
anyone else got any ideas?
Old 06-13-2007, 09:24 AM
00AccordLX5spd's Avatar
Registered User
Looks to me like JimBlake said it all! I sure can't think of anything else!
Well...besides checking to see if your apartment complex has a "lost and found" in the front office. You never know...someone may have found them & turned them in!
Good luck
zil
12-13-2010 11:49 AM
toicy4ya
04-03-2010 04:49 PM
rakeshb76
05-04-2009 10:09 AM
dmich116
12-01-2006 11:29 PM
bgatesman
06-03-2006 02:32 PM
Quick Reply: URGENT HELP NEEDED - KEYS LOST
