Sponsored by:
Sponsored by:
Vibration upon acceleration in turn
Old 06-06-2008, 03:18 PM
cooper4x4
Default Vibration upon acceleration in turn
i have a 97 accord dx 4 dr sedan with the 2.2l.
When accelerating from a stop and turning i have a bad vibration coming from the front end. my first thought would be cv axles but they are fairly new (within 2 years). My next guess would be wheel bearings wearing but I would also expect them to act up when accelerating straight. Tires are brand new.
Any suggestions?
Old 06-06-2008, 06:56 PM
BlkCurrantKord's Avatar
Default RE: Vibration upon acceleration in turn
Last time you had an alignment? Tie rods, ball joints...
Old 06-06-2008, 10:54 PM
deserthonda's Avatar
First chk to make sure that there are no loose ( worn ) suspension parts,,
,if all is ok..
remove the big band from the inner cv joints, pull the boot back enought to stuff a bunch of grease in there, reposition the boot, install a new band , go test drive it ..
Old 06-07-2008, 11:31 AM
drummer1279's Avatar
also make sure there isnt a wheel wieght missing, the tire balance could be off.
Old 06-10-2008, 04:33 PM
cooper4x4
ORIGINAL: deserthonda
,if all is ok..
How is adding grease to the CV boot going to do anything? If the tripod is worn, it will still be worn (and still vibrate) if I add more grease. Not trying to be critical, just curious how this will help.
What suspension parts are consumables on these car? Upper ball joints, lower ball joints, outer tie rods. do these cars have inner tie rods? any other parts I am missing?
Old 06-10-2008, 10:49 PM
I'm curious about the grease too. Wobbling is usually wear causingclearance between the tripod bearing & it's tracks in the inner driver.
Inner tie rods are those shafts coming out from the steering rack. The inner tierod balljoint is inside the rubber bellows. Those don't go bad real often.
Mr_Accord
10-16-2021 09:48 AM
99accord335000
02-06-2018 11:29 PM
ariff
03-04-2010 09:56 PM
Old Sporty
09-14-2008 12:05 PM
mb21
04-09-2008 10:32 AM
Quick Reply: Vibration upon acceleration in turn
