Video: steering makes noise when engine cold and cold weather
Old 11-11-2014, 07:21 PM
d0n's Avatar
d0n
d0n is offline
Default Video: steering makes noise when engine cold and cold weather
Hi,
I have a 2003 Accord 6-speed v6 coupe.
Video of my issue is here:
only happens when the engine is cold. after it warms up it doesn't happen at all.
Thanks for the help.
Old 11-11-2014, 07:27 PM
Probably due to air is entering the power steering pump through the inlet joint O-ring.
DIY Power Steering Pump O-Ring TSB - Drive Accord Honda Forums
Old 12-08-2014, 01:11 AM
oldbeek's Avatar
mine did the same. Honda dealer wanted 750.00 to fix many things. There is an updated red o-ring at the inlet fitting on the pump. .89 cents and 5 minutes to change. Dealers suck!!!
Old 12-09-2014, 05:42 PM
EXV6NIGHTHAWK's Avatar
A LOT of people got screwed for pumps with this issue. Luckily, I knew about the o-ring before my pump started screaming one cold morning.
Old 12-10-2014, 07:42 AM
Low PS fluid level will also cause this problem. Make sure fluid level is good and no leaks.
HYDRALOX
12-31-2012 08:46 AM
justice37
10-26-2012 06:45 PM
dunnskii
02-19-2011 08:04 PM
crazymikeyo5
05-05-2008 09:23 AM
AccordEX
12-04-2006 02:09 AM
Quick Reply: Video: steering makes noise when engine cold and cold weather
