mis fire cylinders 2,5,6
Old 05-10-2014, 10:41 AM
maverick66's Avatar
Default mis fire cylinders 2,5,6
yesterday my girlfriends 2000 accord ex 3.0 started acting up, bad shake going up hill and misfireing codes show cylinders 2,5,6 changed coils and put in a can of dry gas, same results as before, any ideas what else iit could be
Old 05-10-2014, 11:44 AM
shipo's Avatar
Most likely the engine has lost a coil. I felt mine start shaking a month or so ago, and when the shop ran the codes it showed up as three cylinders. I told them that was impossible as it only felt like one. I had them move the coils around and track which cylinder was misfiring, and sure enough, it was only one coil which was bad.
Edit:
Here's a link to the thread: https://www.hondaaccordforum.com/for...24/#post343246
Old 05-10-2014, 01:38 PM
maverick66's Avatar
it only seems to be mis firing when applying fuel going up hill. any chance the filter could be plugged as its in the tank, cars never run below half, im pulling my hair out with this thing, was told by garage it could have skipped a tooth on the timing belt..is that a poss.
Old 05-10-2014, 02:22 PM
shipo's Avatar
Unless you have at the bare minimum of a quarter of a million miles on your car then it is highly unlikely the filter is pugged, and the timing belt jumping a tooth is pretty unlikely as well. If the codes are showing misfires, then you really need to look at the coils.
Old 05-10-2014, 02:47 PM
How may miles are on the spark plugs? I think the maintenance schedule is to change the plugs every 105K miles. Use only the NGK PZFR5F-11 spark plugs that you can pick up at most part stores. Atleast inspect the spark plugs.
Does the 2000 have the coil over plug, or does this still have a distributor? Honda switched around 2000. Inspect the distributor cap and rotor, if you have one.
Old 05-10-2014, 04:04 PM
maverick66's Avatar
plugs changed 8000 miles ago, going to check them again after te rain stops, has coil over plugs
Old 05-11-2014, 11:43 AM
maverick66's Avatar
finally got it thanks all for the help, i played with switching coils around here it was number 4 that was bad however when it thru codes it said 2 5 and 6 but oh well runs like a champ again chnged the plugs too even though they only had about 8000 miles on them they looked fouled from misfiring.. thanks again everyone
Old 05-12-2014, 11:19 AM
Just for grins, to explain the issue about misfiring when climbing a hill...
Possibly the coil was marginal, weak, but still fired a weak spark. Mixture is more difficult to ignite as the pressure gets higher. So closed-throttle, high-vacuum in the manifold, it doesn't misfire.
Dan_99accord
09-11-2013 10:09 PM
alfi
07-07-2011 10:24 AM
wildwildoates
04-13-2011 07:38 AM
johnschommer
07-17-2009 12:01 PM
qu1068311
01-15-2009 07:17 PM
Quick Reply: mis fire cylinders 2,5,6
