What kind of Transmission oil??
Old 04-22-2005, 03:01 AM
94accordprobs
Default What kind of Transmission oil??
I have a 94 accord ex. 4 door 4 cylinder. lately the transmission is shifting hard so i just want to change the transmission oil, because i don't think that it has been done in a while. honda recommends i use Dexron II Automatic Transmissions/Transaxle Fluid (ATF) is there some other type of of trans. oil?
I heard that honda trans. oil is kinda exspensive...how much is it?...and is there some cheaper alternative that will work just as good as the one honda recommends?? Please reply fast.
Old 04-22-2005, 09:07 AM
RTexasF's Avatar
Super Member
Default RE: What kind of Transmission oil??
You can easily find out the cost of the Honda fluid from the source.....call the dealer. This may be one of those times where it is best to use a Honda product instead of a substitute. Are you doing this yourself or having someone else do it?
Dealerships do this service daily and usually have a flat charge for it including the filter if your car requires one. Be aware that a drain and fill does not get all of the old fluid out which is why some folks do it again a month or so later.
Old 04-22-2005, 07:07 PM
Hey there 94accordprobs
I'd recommend using the ATF tranny luid specifically for honda's i recently had to do my moms awhile ago back in the fall, it cost me about 120$ canadian so prolly....80-90$ go get it done but theres a huge difference in teh car now.... DO NOT use DEXRON, i took mine to penzoil to get done and they told em how they had a customer who did have DEXRON used and it messed there accord big time, just go get it done its cheap,and u wont have to do it again for awhile it helps the car run better
Old 04-27-2005, 09:44 PM
Redline - syntethic ATF <--- trust me - will drive 30K on that no prob
Old 05-15-2005, 07:44 PM
Also you could use Royal Purple Synthetic Fluid as well.
BUT, depending on mileage you have if its shifting hard, check the dipstick and see if the fluid looks dark and smells burnt... if it smells badly burnt you may not want to change it because it may cause more damage than good.
Old 05-15-2005, 08:42 PM
Id definatly recommend using the Honda tranny fluid it is more expensive but i had a friend who use the dexron garbage on his and the tranny was worse also honda voided the warranty i had to fluch the tranny on my moms car and we use the ATF honda fluid it runs much better since....
Old 05-15-2005, 11:10 PM
Id go with whatever honda recommends on this one
Old 05-16-2005, 10:44 PM
spend the 100 and some odd dollars on the fluid dont be cheap ecspeccialy if ur gonna ride with "us" hahah... look at it this way 100$ for tranny fluid or 800 on a brand new tranny???? hmmm 100$ looks good to me
Old 05-17-2005, 10:52 AM
accorddriverc's Avatar
I only use the honda fluids on my car
Old 05-17-2005, 10:19 PM
Ya get good quality fluid....honda's is good, but there are better....What kinda ATF crap did you put into it to have to flush it out? BTW did you remember to add the extra bottle to convert the Dextron to the Highly Modified Honda requires, if not that would have been your problem.
Quick Reply: What kind of Transmission oil??
