Sponsored by:
Sponsored by:
Ignitin Cylinder
Old 06-12-2012, 08:49 PM
wmhpm1's Avatar
Default Ignitin Cylinder
Im replacing the ignition cylinder on my 2003 accord ex 6 cyl automatic. So far everything has been straight forward. But I'm stuck on the two bolts on the top. They have no head and look to be security bolts. My question is do I need to cut them off or is there another way to get them off.
Old 06-16-2012, 12:51 PM
joec44's Avatar
Yes there is a way. Use a sharp pounch and a small hammer hit the head of the bolt in a way that it will loosen do one at a time and take your time. when fitting the new one on be sure it is fitted on corectly or key lock will not work use new bolts and tighten untill heads break off good luck!
Old 06-16-2012, 03:06 PM
They are shear bolts. Similar to what joec44 said, you can use a center punch and hammer to turn it off. You would make an indentation on the bolt, then at an angle, use the punch and hammer to loosen it in a counter-clockwise direction.
Here is a link with a picture (post #2) on how to remove the two shear bolts with a center punch and hammer (it is actually very easy and fast to do, probably less than a minute for each shear bolt). A center punch and hammer can be used to loosen screws, nuts, bolts, etc.
Throttle Position Sensor - Honda-Tech
Chris Jameson
02-19-2013 06:39 AM
STINKA621
03-09-2009 07:53 AM
PJ_STYLES_95AccordEx
10-24-2007 09:58 PM
aso432
10-23-2005 10:41 PM
gonecrazy
10-12-2005 11:57 PM
Quick Reply: Ignitin Cylinder
