what size brake line does a 99 accord use - Honda Accord Forum - Honda Accord Enthusiast Forums
Reply
Thread Tools Search this Thread
Old 05-07-2011, 07:55 PM
Default what size brake line does a 99 accord use
Hello, i had a steel brake line rupture on me this morning, and need to replace it. First off is there a quick temp. fix to this problem, like sleeving it with something and clamping it off, and second, what size diameter line do they use on a 99 accord for the steel line to the rear brakes, just have to get it home so it can be repaired.
Old 05-07-2011, 08:30 PM
Google "honda brake line size" for link. It says the size is 3/16" tubing and nut is 10x1mm. you will need a bender, cutter and flare tool which can be rented from auto parts such as autozone, et al.
Not as easy as you might think.
Warning, it there's one hole it may rupture again if you splice a piece in place. I had this happen on a Dodge truck that was driven in salt water on coast.
Old 05-07-2011, 08:51 PM
ARE there any connections between the and back that a new piece could be put in or a way to splice one between fittings
Old 05-08-2011, 06:43 AM
The don't use splice fittings and you'll have to find some tubing fittings to perform a splice.
Reply
Thread Thread Starter Forum Replies Last Post
Where does this line go? robbierob02 General Tech Help 1 01-04-2015 07:27 PM
A/C - warm low pressure line and cold high pressure line eduard General Tech Help 3 05-09-2013 01:11 AM
What OBD does 1990 Honda Accord EX use? Michellekaplan74 General Tech Help 2 03-30-2012 12:41 PM
Where does this vac line go PhilipK Engine & Internal 2 10-31-2007 09:28 PM
Anyone ever use this product line?? blaz72282 Detailing 1 04-01-2007 12:50 AM
Tags
1999, 2000, 93, 94, 99, accord, brake, break, flair, honda, line, lines, lx, pricing, size, steel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
