Sponsored by:
Sponsored by:
Time for timing belt??
Old 01-12-2007, 01:38 AM
Lance Link's Avatar
Default Time for timing belt??
I have a 99 EX V6 with 90K. I'm thinking it's time to replace timing belt. It doesn't have any bad symptoms. Wondering what you guys think? Any other maintenace I should do at the same time? Water pump?
Also have an 02 Odyssey V6 with 80K. Wondering if I should do that one soon also.
Thanks.
Old 01-12-2007, 03:33 AM
Default RE: Time for timing belt??
ORIGINAL: Lance Link
I have a 99 EX V6 with 90K. I'm thinking it's time to replace timing belt. It doesn't have any bad symptoms...
It'll look good & work good, and the belt will look OK. Until maybe 3 hours before the belt breaks. I'd replace it on schedule instead of extending it based on looks.
Old 01-12-2007, 04:39 PM
deserthonda's Avatar
if you got thr extra money do them both ,, if tight on money do the 1 with the higher mileage 99 v6..
you got to keep in ming that the miles on the odometer are not the actual miles on the t-belt, especially if you do mostly city driving. . anytime the you are stopped at traffic lite or behind traffic, miles do not roll up on the odometer but engine is still turning , so t-belt has more miles than indicated on odometer
Old 01-12-2007, 04:47 PM
sir_nasty's Avatar
do the water pump and seals while you're in there if you can afford it... it will save you money in the long run
Old 01-12-2007, 04:56 PM
as Sir-nasty said on doing water pump , it is not a question if you can afford it,, but a must once everything is apart .. also replace the hydraulic tensioner and outer belts
Old 01-12-2007, 06:39 PM
Lance Link's Avatar
Thanks. Any suggestions on replacement parts (belts, tensioner and pump.) Original Honda parts or aftermarket?
Old 01-12-2007, 07:00 PM
sir_nasty's Avatar
A number of people have bought timing belt "kits" and had good luck with them (water pump, seals etc) personally though I'd make sure that at least the belt and water pump are OEM Honda, the other stuff is kind of up to your discretion...
john_pyro
08-04-2019 05:06 PM
ajaybali
11-25-2010 10:56 AM
rakeshb10
06-24-2010 07:34 AM
southpark0000001
10-01-2007 10:03 AM
Tony1M
04-01-2007 05:42 PM
Quick Reply: Time for timing belt??
