Any turbo kit recommendations?
I'm trying to figure out HOW to get some more power into my car. I've played around with the H22 idea, the F20B idea, and I'm considering a turbo F23 as well. If I go the turbo route, I'm shooting for about 215hp. Can anyone recommend some decent kits for me to get started with?
it has been done countless times, the higher the psi the faster your engine will BLOW.
seriously speaking, do not buy cheap ebay turbos, a lot of places wont even install them for you because of the risk. there are a few good sites that will make a custom t3/t4 package for you that will most likely need to be modified but overall a good fit. boosting around 6-8psi will also be your best bet if you plan to drive it everyday.
* you will also need to look into " maybe " upgrading ur ecu, axels, injectors etc... so the added hp can be tuned correctly"
No emission testing here in WV. I'll keep looking around. I haven't made my mind up on an exact goal yet (which is usually my problem).
Graphicbrew
02-22-2010 04:41 PM
