what should be done first?
Old 09-14-2010, 10:03 PM
streetlimitz89's Avatar
Arrow what should be done first?
recently bought a new Reman engine (f23a1) Sohc vtec and i have a turbo kit waiting for install .. what shoiuld i do to the engine before install?? any kind of interenals should be changed .. its a small .47 a/r turbo probally wont push more than 8 psi should i do any internals for this little turbo or should i say Turd-o i am eventually doing a fully built engine VIA bisimoto engineering... but for now i just want to have a little more Get up and go with this little turbo
Old 09-14-2010, 11:05 PM
g22cd5's Avatar
Supper Moderator
your fine with stock internals pushing 8psi. f series engine love boost
Old 09-17-2010, 12:03 AM
corvetteking's Avatar
You should be fine... Where did you get your reman motor at???
Old 10-02-2010, 06:07 AM
burninfuel's Avatar
if you got the motor out and available to work on might as well change the internals while you are at it, atleast if later you decide to up the boost, you know you will already have strong internals that are better than stock to work with
Old 10-02-2010, 06:15 AM
g22cd5's Avatar
Supper Moderator
if you want to do any type of internals just go with rods and valves springs and retainers That’s all the really need to be done...and if you want to crank up the boost past 8psi then that should hold you up to around 350-400hp
Old 10-05-2010, 12:31 PM
g22cd5's Avatar
Supper Moderator
also get ARP head studs so you don't have head lift
Old 10-07-2010, 12:58 PM
sanchdaniel's Avatar
Could you be more specific on what type of rods? I heard their are push rods and some other type. Maybe some brands to choose? Also, it doesn't look like ARP has any head studs for the f23 engine.
Old 10-07-2010, 01:28 PM
g22cd5's Avatar
Supper Moderator
lol disregard my f22bx comment on the PM I 4got your gen accord has he f23 engine.
As for the ARP head studs you can use h23 head studs (call ARP and ask them to be 100% sure). Hondas don't use push rods they are over head cam set up. When I mean rods I mean pistons rods. Bisi makes some eagle makes good rods (and on the cheaper side price wise) few other brands just depend on who you like more.
Old 10-12-2010, 08:58 AM
I'm sure arp makes studs for the f23... As they make them fr the f22.. Also the rods he is talking about are called connecting rods... You can get a set for the 2 to 300 dollar range... You stock pistons and crank like he said should e good to about 300hp at the crank... Then u might wanna consider upgrading other critical engine components...
dgp1961
01-15-2013 06:45 AM
aTYpicalTYrant
04-25-2011 02:12 AM
Honman07
08-30-2007 12:47 PM
mbmoore
08-04-2007 01:00 PM
zelseman
01-09-2006 04:22 AM
Quick Reply: what should be done first?
