fuel Schrader valve location
Hey there I own a 2003 Honda Accord V6, looking to put a Wet nitrous system in place. Before I buy the nitrous I wanna do research and make sure that the nitrous will work with my car. I was wondering if anyone knows the location of the Fuel Line Schrader valve on my car... All I found was a EVAP valve which I am sure isnt the right one.. Thank You
first things first .. i really wouldnt put nitrous on a stock internal engine .. thats the BEST WAY to make sure u get a piston in the oil pan but i will load you the fuel diagram on this page
from the looks of the diagram there is no loaction to Check fuel pressure they simply have fuel line quick disconnects and i guess the dealer has thier own tool to check for pressure
i hope this helps
i hope this helps
As long as you are not going ***** out, a small amount of nitrous will not be bad on a stock internal motor... This is only if you install it correct and install all of the fail safes needed to protect that nice little motor you have there...Check out my nitrous thread for more info if needed... THe fuel schrader valve should be at the end of the fuel rail on the drivers side i believe... Also if you need some advise or better info, just pm me...
