turbo???
Old 03-04-2005, 03:22 AM
phillykid
Default turbo???
i curious if i can just bolt a turno on my 91 accord that has a f22............open for opinions
Old 03-17-2005, 05:45 PM
Default RE: turbo???
yea just find a manifold and turbo and u should be in business ... or just fina a kit an h23 turbo will also fit a f22 motor what year is ur beacuse juss which f22 is it tho if its a f22b it wont work if its a f22a it will but any ways go to http://www.turbokits.com and it should have ur turbo in there any thing to help. Payce!
Old 06-28-2005, 06:20 PM
Just was lookin through this post. How do i know if i have a f22a or f22b; and what's the difference. I have a 92 Accord LX?
Old 06-29-2005, 07:17 PM
6thgen's Avatar
Look on the block in the front of your engine...it should be engraved.
Old 12-06-2005, 01:46 AM
what kind of psi can i run on stock internals
Old 12-06-2005, 12:19 PM
6thgen's Avatar
8+psi will run, but how long is the question. It's been seen that after 8 psi the bottom end (ringlands and rods)is going through it. Some have run 12psi for a couple years while others didn't last a year at those pressures, but no one wants their engine to unexpectedly crap itself no matter how long it does or doesn't hold up.
Old 12-10-2005, 02:09 PM
tcodi
I don't understand how people can say that you can run 8psi without modifying internals?
If your motor is 10:1 now it will be 15:1.
Where do you plan on filling up your tank? I haven't seen 108 octane fuel at many gas
stations lately.
Old 12-13-2005, 11:55 AM
6thgen's Avatar
ORIGINAL: tcodi
stations lately.
People say it because they do it, simply. I'm not sure of the compression on the F22, but the F23 is 9.3:1. Personally I wouldn't run over 7 on stock internals, but the fact is a lot of people do sucessfully, but like I said, for how long? There's cases of engines going after 6 months and cases of running higher than 8 with a good tune and going multiple years. This is based on the turbo accords that I'm am familiar with. The F23 and F22b are identical in some aspects.
Old 12-18-2005, 12:48 AM
chile
most folks run 6 psi on an all stock motor but i've seen a few running 10 w/out problems...as with anything, your results will vary but i would suggest staying at 6 or so if you plan to jump on it...i am getting ready to throw a T25 (yeah, yeah, i know...) with a 2g DSM mani, 450cc dsm injectors, chipped P06 ecu and fmic...i've been reading up on it and i figure it'll take about a week to do it right but i know most do it over a weekend or so...research pays...
Old 12-19-2005, 05:59 PM
6thgen's Avatar
ORIGINAL: chile
DSM Mani on what engine? I see you going to fund the JY.
Quick Reply: turbo???
