screeching noise when I start the car
Old 10-17-2008, 09:00 PM
Jcaleno's Avatar
Default screeching noise when I start the car
Lately (for the past month and a half) when i start the car the engine makes this high pitch screeching noise, its only for the start up of the engine, it then goes away in a second and I dont hear it again until I start the car again from cold, but if the engine is warm and i start the car again the sound isn't there. Any suggestions?
Old 10-18-2008, 10:39 AM
falkore24's Avatar
Default RE: screeching noise when I start the car
Check the accessory belts.
Old 10-19-2008, 09:43 PM
ford's Avatar
might be the belts as folk said...
Old 10-20-2008, 10:14 AM
finch13's Avatar
Yay loose belts. Rubber gets harder (and less tacky) in colder temps. Friction from the pulley spinning against the belts heats it up until they get sticky and catches, ending the squealing. Just adjust the tension on them. Belt deflection is 1/4" for 7" between pullies and 1/2" for 13"+ gaps. < That's how far the belt moves when you push on it.
Old 10-22-2008, 01:27 PM
Jcaleno's Avatar
ok, which belt specifically should I be checking?
Old 10-22-2008, 01:31 PM
finch13's Avatar
All of the accessory belts (power steering, alternator, and A/C).... The only ones you can see. The only other belts on the car (timing) are under cover on the driver side of the engine.
Old 10-24-2008, 01:54 PM
klrspz's Avatar
push/pull on them, if they feel stretched, that's the issue... if still snug, there might be some oil/lubricant on the pully/belt.
yoyoyoda
07-20-2011 06:18 PM
Jalvare4
07-14-2011 01:42 PM
AccordLXMaster
08-21-2009 07:38 AM
Johnene
07-16-2009 03:20 PM
vmysore
08-08-2008 09:25 AM
Quick Reply: screeching noise when I start the car
