2005 Accord LX CAMBER KIT - Best??
2005 Accord LX 4 Cylinder Sedan.
Neuspeed Lowering Springs (1½" drop)
ruining the inside tread on the rear tires.
Recommended that I get a REAR CAMBER KIT ...
What's the best?? Please help make recommendations.
Which one did you get? I was looking at the TruHart camber kit and adjustable upper control arms.
Yeah, Duh! Would've been nice for me to let you know which I purchased!
Wicked Tuning 03-07 Honda Accord, 04-08 Acura TSX Spec-3 Rear Camber Arms - Gunmetal
VERY High Quality - Heavy Camber kit - I would highly recommend.
FOLLOW-UP: So the shop installed the camber kits, and the alignment was "correct" but it STILL WIPED OUT another damn set of tires!! Is it possible to align this car witht he lowering springs / camber kit in place?? Or do I have to revert back to an OEM strut assembly??
I also got the ingalls camber and toe kit along hit the true hart camber arms. the ingalls kit replaces two of the trailing arms that the camber arm doesn't. So you basically replace three of the arms I think it was $189 for it and its DIY simple just get it aligned after. have had no problems with tire wear sitting on tein street advance coilovers.
thunder_x
05-17-2006 08:26 PM
19accord95
02-11-2006 02:06 AM
