ABS troubles
Old 12-13-2005, 01:11 PM
mbmsg
Default ABS troubles
I have a 96 EX v6 accord. The ABS light is coming on occasionally. Fluid is good in resevior, Is there a resevior for just the ABS? could it be a bad sensor or connection?
Old 12-23-2005, 03:50 AM
deserthonda's Avatar
Default RE: ABS troubles
the abs reservoir is on the left ( driver ) frt fender .. what i have seen a lot is the abs modulator leak and need to be resealed..... if modulator is leaking the dealer might want you to buy the whole assembly ( big bucks )... have them reseal it first ,i have done a few of them with good results...........also pull the abs code and post it here
Old 01-15-2006, 01:08 PM
pepecrower
How difficult is to reseal the pump?? I have similiar problem I pull the codes and got code 1 pump overun How do fix this? Ive been told also might have to replace the whole pump.
93Accord2.2
11-07-2013 07:10 AM
add25
12-26-2007 10:04 AM
IWL BCNU
09-09-2007 10:07 AM
FELON
04-17-2007 10:29 PM
89HondaLegend
04-06-2006 05:48 AM
Quick Reply: ABS troubles
