Does the 9th Gen Accord have f/r camber adjustment?
Old 08-01-2014, 04:32 PM
Hot Brass's Avatar
Default Does the 9th Gen Accord have f/r camber adjustment?
Just wondering if someone knows for sure if there is adjustment for the front and rear camber on the 9th Gen Accord (Touring), as I thought I read somewhere that only toe-in/out was adjustable.I realize one can buy camber kits,but I am talking bone stock suspension. Thanks,HB
Old 08-18-2014, 07:21 PM
Hot Brass's Avatar
According to the 'other site',there is one locating pin at the top of each strut that can be twisted off with a nut(10mm?) and each strut can be moved in or out an extra + or - 1 degree...I dunno?! HB
Old 08-19-2014, 11:45 AM
It's hard to tell anything from the parts drawings. I don't have a shop manual for 2013-2014.
The front knuckle clamps directly around the bottom end of the shock, so it's hard to imagine any adjustment there. It might be possible for a tiny adjustment by moving around the top of the shock. Can't tell how much room there is in the shock-tower, even if you enlarge the bolt-holes. I don't see an obvious alignment pin up there, you'd have to deal with that too.
The rear has an upper control arm. That might be more promising. Again, there isn't anything obvious, but using the space in the existing bolt-holes, or enlarging the bolt holes, might get you a little bit of camber.
Old 08-20-2014, 06:20 AM
Hot Brass's Avatar
Thanks! Hot Brass
Old 09-06-2020, 07:15 AM
Default Cvt?
Is there anyone who has had 20s and had problems with the rubberband like CVT tranny?I have a 2017 cr7 sport and have 3 sets of 18s and one set of 17x9.5+22 te37s.(loveRIMS)
I was offered a good ticket on 20x8.5+20,20x10+20 crKai Rota from a family member.I just dont wanna eff up my ugly Cvt since its my daily commuter..much thanks for any real world 1st hand data🙏
girobers
01-08-2017 09:00 PM
bayn8v
06-22-2014 09:34 PM
signaturechrome
01-19-2014 04:54 AM
JohnnySasakiMGS
04-22-2013 04:16 PM
Quick Reply: Does the 9th Gen Accord have f/r camber adjustment?
