2014 EXL Navi Front Tires unusual wear
Old 05-25-2015, 03:01 PM
Roque Nichols's Avatar
Default 2014 EXL Navi Front Tires unusual wear
Hi All, I have been experiencing some issues with the wear of my front tires, the wear is excessive at 20k miles, similar to when you have bad struts and the tire wears off in the outside of the contact surface. I talked to the dealer and they said is a problem with the tires, and they talk to goodyear (have goodyear assurance) and they said the problem is due to bad or extreme driving habits!!! No surprise to me about their response. I took on the task on checking all other accords from this generation that crossed my way and surprise surprise!! All accord drivers have very bad driving habits! I have checked about ten vehicles with goodyears, continentals and Michelins and all have the same problem, in my opinion is a problem with the redisigned front suspension of accords. Any one has the same issues? please check your tires. I will share all the pictures i got from other vehicles. Thanks
Old 05-25-2015, 03:56 PM
Default This are the pictures taken from different vehicles.
Here are the pictures, I have lots more.
Attached Thumbnails 2014 EXL Navi Front Tires unusual wear-img-20150504-wa0005.jpg   2014 EXL Navi Front Tires unusual wear-img-20150504-wa0007.jpg
Old 05-25-2015, 09:16 PM
Talking Hello Member **
I'm going to move this to the Tire and Wheel thread to get some play on it..Must post in areas where they will get you some answers..
Attached Thumbnails 2014 EXL Navi Front Tires unusual wear-memorialday-frompolice.jpg
Old 08-09-2015, 09:30 AM
travrach's Avatar
It's not likely that Honda will do anything for you, so before you keep destroying tires, find a good alignment shop. Clearly explain what you have found and tell them you want it straight even if a camber kit needs to be installed.
This helps explain alignments more if you want to read up on it.
http://www.tirerack.com/tires/tirete...e.jsp?techid=4
totem
08-02-2014 03:14 PM
dkim88
12-12-2013 09:07 AM
enochyoo
09-04-2012 12:56 AM
olegwild
07-21-2010 03:24 PM
tommy
01-04-2007 11:36 AM
Quick Reply: 2014 EXL Navi Front Tires unusual wear
