needs urgent attention
hi guyz
am in the process of negotiatin a buy
a set of rims that look super cool for a cool price
Problem i need confirmation that i got the riht ofset
Size : Fronts: 18x8.5 Rears: 18x9.5
Pcd : 114.3
offsets : Front 32mm / Rear 37mm
thanx
my car = Honda accord 2007 saloon 4 dr 4 cyl
Pcd : 114.3
thanx
You need to measure your original rims to determine the offset. That is the rim width divided by two minus the distance from the front of the rim to back surface that touches the hub. Need to make sure the offset is the same type: positive or negative. If you're dealing with positive offset (old rims and new) then if the new offsets are greater your wheel will sink more into the wells. So you need to measure how much room you have available with old wheels until interference and rubing, which will require spacers - that'll tell you how much you can go into the well. Best to measure and do a sketch with old and new measurements to see if it'll work for you.
02-21-2014 12:49 AM
09-30-2013 12:44 AM
03-19-2008 08:29 AM
03-18-2008 09:45 AM
03-08-2008 04:10 PM
