What Size Tire for 93 Honda Accord?
Old 03-28-2007, 12:51 PM
RoKnAzn's Avatar
Default What Size Tire for 93 Honda Accord?
Well, I have stock rims on the Hondawith 195/60R15.It's time to replace the rear tires. So, I was wondering what is a good size for good gas mileage...
Old 03-28-2007, 01:59 PM
Default RE: What Size Tire for 93 Honda Accord?
Unless you are changing the rim size, the stock 195/60 r15 is your best choice. Also a tire with a mild tread pattern as well.
Old 03-28-2007, 02:30 PM
RoKnAzn's Avatar
Just wanted to make sure...I thinking about getting these tires for the rear and later on for the front...
Falken Ziex ZE-512
Old 03-28-2007, 05:27 PM
Those are a good set for normal driving. While I still had my original rims I used these:
http://www.discounttiredirect.com/di...d=15&ar=60
I had a great driving experience with the,. They were quiet and gave me good grip. PLus you can't beat 80,000 mile warranty, and these things seemed to last forever with a 720 rating. After 4 years with them the tread depth was still thick enough for them had only gone down 2/32.
I'd also say do all four of your tires. Different tires wear at different rates, so you could be fine now but a bit down the road you may start to get traction issues as the different types grip in different ways. And those will only be compunded if they are rotated and you get different types in the front, that could lead to steering complications.
Old 03-28-2007, 06:50 PM
RoKnAzn's Avatar
This car will be used as a Good Gas Mileage car. The ole man is going to drive this to work after I get all the bugs fixed out...
Anthony
Old 03-30-2007, 01:54 AM
[sm=massbounce.gif]Hello there Member RoKnAzn...
Best tire for that ride that will give you the most miles per gallon is of course the Original equipment size tire...that's why they have those sizes already on the cars....HONEST [sm=exactly.gif]
Old 04-12-2007, 06:21 PM
RoKnAzn's Avatar
I forgot..It's a Honda. I had a Jeep and theirs are different.. Anyways. I had an accident with the Honda Accord Busted 2 Rims. So far I cant find any Stocks on for Cheap. But I got the Hook up on MSR, BOSS, or Eagle Alloy. I have Black car on Tan. What size Should I get? and 4x114.3/4x115mm BP right?
Thanks
Anthony
Old 04-12-2007, 07:44 PM
Correct on the bolt pattern. 15 inch for stock size rims. CB7 Accords can go up to 17s before it starts to look wierd.
Old 04-12-2007, 07:58 PM
RoKnAzn's Avatar
17 huh? u got any styles from BOSS, MSR, and Eagle Alloy. That would look good on a CB7 Accords? Oh yea..How wide can I go?
Old 04-12-2007, 11:18 PM
I went for 7.5 width vs. the stock 5. I'm not sure what styles they have that would look good. When I went searching for wheels I had a particular style in mind and didn't pay attention to manufacturers. I've seen width's up to 8.5 available , but I'm not sure what sort of clearance concerns that may pose. Mine do not rub or bind in anyway even with the car lowered 2.5.
Quick Reply: What Size Tire for 93 Honda Accord?
