honda accord 92 ex overheating replaced EVERYTHING
  Printable Version
Honda Accord Forums >> General >> General Tech Help >> honda accord 92 ex overheating replaced EVERYTHING Page: [1] 2 3 4   next >   >>
Login
honda accord 92 ex overheating replaced EVERYTHING - 4/20/2006 8:35:02 PM
copa708
Status: offline
My accord 92 keeps overheating when idle or in traffic. my A/C also turns warmer when i'm idle... i can understand getting slightly warmer but it gets a lot warmer to where i'd just rather have the window open. I have replaced the thermostat and i don't think the old one worked anyways, i flushed out the coolant and replaced it with dexcool. i replaced the cap so i'm sure that's not the issue. However i have noticed that when my foot is on the gas the gauge goes back down. i tested that to make sure it wasn't the fans because i don't really feel like replacing those nor do i know when they come on... i'm guessing when the thermostat pops but apparently it hasn't felt the need to do that or the fans just don't work... either way my FIRST problem is that when i put my foot on the gas, that's the only time it cools down. about the radiator cap, i just bought a new one and it seems really difficult to get on compared to the other one... could that have something to do with it? i saw that someone had the same problem i did earlier in the posts and they just replaced the cap... so is it possible i just bought a faulty cap? any input would be nice! thanks.
Post #: 1
RE: honda accord 92 ex overheating replaced EVERYTHING - 4/20/2006 8:55:26 PM
deserthonda
Status: offline
it sounds like a fan issue to me..........
try an easy thing first,, start the car put the a/c on make sure the compressor is engaged and both fans should work, this trick will work assuming all is ok with the a/c system.. Now if fans do not work, get a big screwdriver and bang on the fan motor if fan comes on you got a bad motor ,, if fan still does not come on , then we have to trouble shoot it the long way around..
first off, chk the fuses , underhood fuse box, the relay, underhood fuse box, if ok. start car and let it warm up, till the t-stat opens, lower radiator hose must feel hot ,, if after running for a while and temp gauge starts to go above 1/2,, .. jump the fan switch,, it is located on the t-stat housing, green plug 2 wires going to it,, unplug it and jump those 2 wires together at the green connector, if fans come on you got a bad fan switch,,
if they still do not come on, chk to see if you get power and ground at fan motor plug . if you do,, you got bad motor if you don't you could have bad wiring to fan motor,
try this and post results
One of these days i will write an A to Z on how to trouble shoot non working fans..
(in reply to copa708)
Post #: 2
RE: honda accord 92 ex overheating replaced EVERYTHING - 4/21/2006 12:12:55 AM
AgentofDarkness
Status: offline
You could put a meter across the two wires that go to the fan motor. If the meter reads 12 volts, it means that the power is getting to fan motor. If the fan doesn't start, then it means that the fan is bad.
Post #: 3
RE: honda accord 92 ex overheating replaced EVERYTHING - 4/21/2006 5:18:44 AM
lightshow
Status: offline
absolutely.........i think it could also be your water pump
(in reply to AgentofDarkness)
Post #: 4
RE: honda accord 92 ex overheating replaced EVERYTHING - 4/21/2006 2:19:18 PM
copa708
Status: offline
thanks guys, from the things you've told me i do believe it's probably the fan. however, why does the engine cool down when i put my foot on the gas? does it cycle more coolant into it or something? also, how do i check a fuse to see if it's working? i found it but i'm not sure how to test it to make sure it isn't the fuse without buying a new one. BOTH fans don't seem to be working in any situation. I'm guessing it's either the wiring or the fuse. I do have a voltimeter so i can test the wires going into it. any suggestions would be a lot of help. thanks.
(in reply to lightshow)
Post #: 5
RE: honda accord 92 ex overheating replaced EVERYTHING - 4/21/2006 6:12:59 PM
AgentofDarkness
Status: offline
It could be possible that when you hit the gas, you are going fast. When you go fast more air passes over/through the radiator and cools off the coolant in the radiator. The fan pushes air into the radiator and when you go really fast your car runs into alot of air, doing the same thing as the fan. If you go on the highway and your car doesn't overheat then your fan is the suspect. I dunno if you want to try this.
Post #: 6
RE: honda accord 92 ex overheating replaced EVERYTHING - 4/22/2006 9:56:25 AM
Hondamatic
Status: offline
If you haven't replaced the waterpump I'll put my money on that.
I had the SAME problem. The reason the guage would go down when your pressing the gas is that there is no flow in your system till you rev it up because the fins on your waterpump are probably toast (my situation) The fans would also NOT come on because the temp sensor for the fan is on the thermostat housing and was not getting any flow of "HOT" water to that because of the bad thermostat and the fans never came on making me think the fans were dead. If you look up my post history you can probably see the saga that I had with it and it just turned out to be the waterpump.
HTH,
Brendan.
_____________________________
1991 Accord SE <- Crashed *see classfied section*
1987 Mitsu Montero (5spd 2.6l Turbo I/C) 2dr
1994 Mitsu Montero 3.5l SR - Loaded.
Post #: 7
RE: honda accord 92 ex overheating replaced EVERYTHING - 4/22/2006 12:01:53 PM
copa708
Status: offline
well guys my cars old and i just started investing my time and money into fixing it because it just apparently needs it. so i'm going to go ahead and fix the waterpump and also fix the fans... how difficult would it be to fix the waterpump and how would i go about doing this? also, how difficult would it be to replace every aspect of the fans (besides the thermostat because i had just replaced it) and also how owuld i do this as well. I should probably get a manual but at the same time there aren't large free portions of my day that i can sacrifice often. thanks guys... all your input is being appreciated.
(in reply to Hondamatic)
Post #: 8
RE: honda accord 92 ex overheating replaced EVERYTHING - 4/22/2006 12:28:46 PM
Hondamatic
Status: offline
Give us some history on the car?
How many miles? When was the timing belt done if at all?
It takes roughly 4 hours to do the waterpump and timing belt on this engine. Depending on your level of expertise, you can probably tack on a couple more hours to that, perhaps even turn it into a weekend project.
I recommend getting one of those kits off ebay that include a new waterpump, tensioner bearings, timing belt, balance shaft belt, and a couple various seals. It's good to do all that at the same time while you're in there doing either the waterpump or timing belt.
Regarding the FAN issue, if the waterpump is not circulating water, the fans will not come on because no hot water is reaching the fan switch on the t-stat housing as I said in my last post. If the car has over 100k miles and the timing belt hasn't been replaced, you're better off starting there and replacing the waterpump in the process.
Brendan.
Post #: 9
RE: honda accord 92 ex overheating replaced EVERYTHING - 4/22/2006 12:32:05 PM
Hondamatic
Status: offline
That's what my water pump looked like that came out of a 30-40k JDM motor.
Post #: 10
RE: honda accord 92 ex overheating replaced EVERYTHING - 4/22/2006 12:35:22 PM
copa708
Status: offline
ok thanks, yeah my honda was my brother's before mine, and before that i'm not sure what the owner did with it or if he took care of it. i just purchased a new timing belt because it makes a loud screeching sound... i also got the other belt incase it might be that one. yah i read on how this might take 5 hours to do... i guess i'll have to make it a weekend project if i can probably next week. are things for the water pump purchased in town? miles are 210,000 which is quite a bit i realize... but i'm going to soon get a new car and i'd love to make this a car i can just fool around with and take my time on it since i won't be needing it. but fixing it up before i sell it would be nice. and sorry i misunderstood the last post... i didn't connect that the water pump would affect the fans but thinking about it i can see how it affects it. so new project = timing belt and water pump. should i ask how to do that or would i be better off purchasing a honda manual?
Post #: 11
RE: honda accord 92 ex overheating replaced EVERYTHING - 4/22/2006 12:38:00 PM
deserthonda
Status: offline
if the lower radiator hose feels hot , than it means t-stat is opening, means water pump is working properly..... if water pump is not leaking and you are not due fpr a timing belt ,,By replacing the water pump you are wasting your money and time,,,,,,,,,
the problem is not the water pump...
you need to trouble shoot it step by step,,,,,,,,follow the instruction i gave you , do not skip a step here and there
DO NOT start replacing parts just because someone here says it is this , it is that.. you need to DIAGNOSE, DIAGNOSE DIAGNOSE, then fix and or replace only what is needed ..
have you tried anything at all of what i have adviced you ?? if not ..why not ?? and if yes post the results..
Post #: 12
RE: honda accord 92 ex overheating replaced EVERYTHING - 4/22/2006 12:40:57 PM
copa708
Status: offline
the bottom radiator hose is not nearly as hot as the top one... it's always within a temperature i'm capable of having my hand on it without any discomfort. the fuse i'm not sure how to check, and i have yet to use a meter to see if the fans are messed up. but yeah the radiator hose is very cool compared to the top one.
(in reply to deserthonda)
Post #: 13
RE: honda accord 92 ex overheating replaced EVERYTHING - 4/22/2006 12:49:55 PM
Hondamatic
Status: offline
Sorry Deserhonda I wasn't trying to go against your suggestions, I think he should definetly start with checking fans and working back, checking hoses, etc.. I was saying that if the timing belt hasn't been done in a while it should be done anyway, and usually you replace the waterpump, etc, while your in there doing that, right?
I'd still put money on the waterpump
Good luck copa708, if you are planning on doing your own work on a 210k car, I think you might want to purchase a service manual
Post #: 14
RE: honda accord 92 ex overheating replaced EVERYTHING - 4/22/2006 12:59:04 PM
deserthonda
Status: offline
quote:
ORIGINAL: copa708
if the lower radiator hose is just cool ,,whle the top hose is hot.........you could have as tuck closed t-stat ..or corroded fins in the water pump , or very low on coolant ..if t-stat does not open fans will not come on..
Post #: 15
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
wheelbrokera6763
sir_nasty6303
falkore245545
00accordlx5s3797
deserthonda3568
19accord973117
jimblake3082
finch133007
smaglik2594
live2rice2406
New Vendors
Sportwing
