horrible problem
  Printable Version
Honda Accord >> General >> General Tech Help >> horrible problem Page: [1]
Login
horrible problem - 7/22/2008 11:40:58 AM
tbird07
Status: offline
I have a 1994 Honda Accord Ex it is throwing a crankshaft position sensor code but from what i understand it is in the distributor so i replaced the distributor and it is still throwing the same code but the car also wont rev above 3500 rpms and i just can''t figure out why and i dont know how to fix it does anyone no what the problem could be
Post #: 1
RE: horrible problem - 7/22/2008 12:55:25 PM
JimBlake
Status: offline
Did you rule out wiring problems (loose/dirty/corroded plugs) first?
_____________________________
'03 Accord & '07 Civic
'01 Saab 9³ & '05 9²x
(in reply to tbird07)
Post #: 2
RE: horrible problem - 7/23/2008 10:08:36 AM
tbird07
Status: offline
yea i have ruled out wiring problems i honestly think but i dont know maybe computer problem or it jumped time
(in reply to JimBlake)
Post #: 3
RE: horrible problem - 7/23/2008 12:16:40 PM
JimBlake
Status: offline
Yeah, check cam timing - thats not too hard to rule it out.
ECU is generally pretty robust so I tend to think of other stuff first.
Post #: 4
RE: horrible problem - 7/24/2008 1:38:03 PM
tbird07
Status: offline
what would cause the car to throw a CKP code
Post #: 5
RE: horrible problem - 7/24/2008 1:41:54 PM
falkore24
Status: offline
falkore24's photo gallery
Is the check engine light flashing?  Limp-home mode >3500 rpm limit
2006 Scion TC (ZPI-18G pending)
2000 V6-AT (RIP 3G)
Temp Search thanks to Finch13
Post #: 6
RE: horrible problem - 7/25/2008 11:23:39 AM
brayner
Status: offline
have you checked the obvious? the crank position sensor? If it''s unplugged the engine will not start. it may be damaged or have excessive debris on/arounf it
94 Accord EX wagon 4-cyl VTEC F22B1 auto
(in reply to falkore24)
Post #: 7
RE: horrible problem - 7/25/2008 5:18:30 PM
tbird07
Status: offline
yes i checked the sensor and it is plugged in and when it is started the check engine light doesn''t blink
(in reply to brayner)
Post #: 8
RE: horrible problem - 7/26/2008 6:45:01 AM
TexasHonda
Status: online
There are several crankshaft position sensor errors. What specific error code do you get from the ECU.
See you down the ROW
1994 Accord EX
Post #: 9
RE: horrible problem - 7/28/2008 6:07:59 AM
JimBlake
Status: offline
1994 is OBD-1 so I think theres only one CKP code (4).
(in reply to TexasHonda)
Post #: 10
RE: horrible problem - 8/4/2008 12:16:13 PM
tbird07
Status: offline
i only got one code from the check engine light and that was 4 ive searched all week and i finally got another ecu u for the car now it will rev past 3500 rpm put it still runs like shyt
Post #: 11
RE: horrible problem - 8/4/2008 12:16:46 PM
tbird07
Status: offline
it is missing and has no power to what so ever
Post #: 12
Page:   [1]
Honda Accord Forum >> General >> General Tech Help
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
wheelbrokera6765
sir_nasty6303
falkore245545
00accordlx5s3797
deserthonda3568
19accord973117
jimblake3082
finch133007
smaglik2594
live2rice2406
New Vendors
Sportwing
