how much psi
  Printable Version
Honda Accord Forums >> Your Ride >> Nitrous, Super Chargers, & Turbos >> how much psi Page: [1] 2 3   next >   >>
Login
how much psi - 10/27/2006 12:35:48 AM
2002haccord
Status: offline
2002haccord's photo gallery
i wasdoing sum research on turboing a f23 and i was reading in honda tech that you can run up to 17 psi without doing nothing internal in any f series block just to put head studs. wat do you guys think
_____________________________
2002 accord ex
2.3 cyl vtec
Post #: 1
RE: how much psi - 10/27/2006 2:02:29 PM
19Accord97
Status: offline
19Accord97's photo gallery
I have heard the max is 8psi though I could be thinking of a different block
*Quit
Later
(in reply to 2002haccord)
Post #: 2
RE: how much psi - 10/27/2006 4:01:17 PM
2002haccord
Status: offline
yeah i herd that too actually heard it safe from 8 to 10 psi
2002 accord ex
2.3 cyl vtec
(in reply to 19Accord97)
Post #: 3
RE: how much psi - 10/28/2006 2:04:02 AM
tom15425
Status: offline
tom15425's photo gallery
I'd run 8 to be safe. To run higher boost like that I'd think you would need at least valve springs, retainers, forged pistons, and rods as far as internals go. 17psi is a good amount so, there may be more you'd need to do that I'm not aware of. You would probably have to drop your compression and what not.
Post #: 4
RE: how much psi - 10/30/2006 12:43:34 AM
marbro
Status: offline
ive heard claims of running 17psi on f22's with no problems, but im sure its not for long
a safe amount is 7 to 8 psi but even at that point if you have old rings they will go out so rings would be a needed upgrade regardless
(in reply to tom15425)
Post #: 5
RE: how much psi - 10/30/2006 3:49:26 AM
YeuEmMaiMai
Status: offline
7-8 PSI if you want a reliable daily driver....go much above that and you will be needing new rings and valve train components....not to mention forged internals
Jesus is Salvation
White 2002 Acura CL type S. 68K and change
Criminals thrive upon the intolerence of society''s understanding.....and political correctness
(in reply to marbro)
Post #: 6
RE: how much psi - 10/30/2006 3:19:53 PM
2002haccord
Status: offline
yeah thats wat i heard
2002 accord ex
2.3 cyl vtec
(in reply to YeuEmMaiMai)
Post #: 7
RE: how much psi - 10/30/2006 3:46:33 PM
sir_nasty
Status: offline
I'll back up the 8 psi statement.... but even at 6 psi if you wanted to be REALLY safe you're going to gain a tremendous amount of horsepower.... I think if memory serves right an f22 with 8 psi turbo is calculated to put out 210-225 hp? so do 4 psi, run that for a while and you'll have a blast, when it gets a bit "normal" feeling then kick up to 6 psi, then again to 8 psi later and keep yourself entertained while you save the cash for the huge upgrade
1981 Civic Station Wagon - ROhnda (Really Old Honda)
1981 Honda CB650 Motorcylce - WHEE What More can I say?
2000 Lexus RX 300 - Oooh baby my wife let me drive it once!!
Post #: 8
RE: how much psi - 10/31/2006 4:21:49 PM
SKHEMR
Status: offline
SKHEMR's photo gallery
As far as the head studs go, for f23 engine the stock head bolts are stronger the ARP studs. Iv'e boost'd up to 18psi and had no problem, but my engine is built. But normal boost for me is 12-13.
(in reply to sir_nasty)
Post #: 9
RE: how much psi - 10/31/2006 6:15:03 PM
2002haccord
Status: offline
quote:
ORIGINAL: SKHEMR
wat kind of internal work have u done in your engine
2002 accord ex
2.3 cyl vtec
(in reply to SKHEMR)
Post #: 10
RE: how much psi - 10/31/2006 7:27:17 PM
SKHEMR
Status: offline
87.5mm arias pistons
crower rods
block re sleeved
valves,springs,port&polish
The works!!!
Post #: 11
RE: how much psi - 10/31/2006 7:35:56 PM
2002haccord
Status: offline
how much did u spend to beef up the internals
2002 accord ex
2.3 cyl vtec
Post #: 12
RE: how much psi - 10/31/2006 9:05:37 PM
SKHEMR
Status: offline
To damn much
Post #: 13
RE: how much psi - 10/31/2006 9:08:57 PM
SKHEMR
Status: offline
About $7000 the first time, the piston blow so now it's in the shop again and so far it's cost me about $2400. It was $1875 to get the block re sleeved new piston and to have the heads re decked.
Post #: 14
RE: how much psi - 10/31/2006 9:10:37 PM
SKHEMR
Status: offline
go to search and type in bad pistons to see the pictures.
Post #: 15
Honda Accord Forum >> Your Ride >> Nitrous, Super Chargers, & Turbos
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
wheelbrokera6763
sir_nasty6303
falkore245545
00accordlx5s3797
deserthonda3568
19accord973117
jimblake3082
finch133007
smaglik2594
live2rice2406
New Vendors
Sportwing
