how to remove an old ignition switch to replace it
Login | |
how to remove an old ignition switch to replace it - 5/26/2008 5:06:45 PM
DA KID RYU
Score: 0 Joined: 11/7/2007 Status: offline
yea can some one point to me how to remove an old ignition switch for a new one.. thanks in advance
_____________________________
94 Honda Accord lx f22b2 stick Aem sri Aem tru pulleys exedy oem clutch obx header (thanks to 19accord97) apc 9.3 spark plug wire Life is what u make it.. not what people tell u to be..
RE: how to remove an old ignition switch to replace it - 5/26/2008 10:19:43 PM
finch13
Score: 0 Joined: 6/7/2007 From: St. Paul, MN Status: offline
This is for a 6th gen, but it should be similar for you. - Remove the top and bottom steering column covers (3 screws on bottom, clips on top) - Unscrew the 2 screws holding the switch in (it's on the left side of the column attached to the end of the key cylinder) - Unplug the ignition harness from the driver kick panel fuse box - Remove the switch. To install - Slide the new switch over the the square shaped end of the key cylinder. - Plug the harness in. - Put the covers back on. I typed it fast, let me know if you need more detail.
-> USE ME TO SEARCH HAF <- 1999 Accord LX F23A1 5MT
RE: how to remove an old ignition switch to replace it - 5/27/2008 12:10:12 PM
lightshow
Score: 0 Joined: 1/6/2006 Status: offline
do you want to remove just the cylinder or the whole thing?
RE: how to remove an old ignition switch to replace it - 5/27/2008 2:59:12 PM
finch13
If you want to remove the key cylinder and the switch as a complete assembly is to a.) cut slots in the 2 shear bolts holding the cylinder to the steering column and remove them with a slotted screwdriver or b.) drill the bolts out. I've done B and it's difficult considering the limited space you have to work with. If I ever had to do it again I'd try A with a Dremel tool first.
RE: how to remove an old ignition switch to replace it - 5/27/2008 10:17:57 PM
DA KID RYU
im sorry i mean the whole thing i had to start my car with a screw driver for a while.. so i need to know how to take the whole thing off... yea the 2 bolts on top are strip so but a slot so i can take it off...thanks
RE: how to remove an old ignition switch to replace it - 5/27/2008 10:23:53 PM
finch13
They're shear bolts. The bolt heads are designed to shear right off at a certain torque, most likely to prevent tampering with the ignition if you're car is in the process of getting stolen, but I really have no clue. All I know is that when I removed the ignition assembly to sell, it was a major PITA to drop down the steering column to get a drill in there. Dremel with a cut-off wheel should do the trick.
RE: how to remove an old ignition switch to replace it - 5/27/2008 10:58:14 PM
DA KID RYU
yea i think i have one of the dremel how just cut the whole thing off.... of just the bolts
RE: how to remove an old ignition switch to replace it - 5/27/2008 11:00:11 PM
finch13
The bolts look like big rivets on either side. Just cut slots into them s a flat head screwdriver will fit. If you cut the bolts you're just, in theory, shearing them again and you'll have to extract them outside of the car. I've done it and it's not easy.
RE: how to remove an old ignition switch to replace it - 5/27/2008 11:01:21 PM
finch13
You do know that if you replace the key cylinder, your ignition key won't match the door and trunk locks, right?
RE: how to remove an old ignition switch to replace it - 5/27/2008 11:02:53 PM
DA KID RYU
where do i get bolts like dat if i happen to mest them up or cut them to much
RE: how to remove an old ignition switch to replace it - 5/27/2008 11:09:10 PM
finch13
Well a new ignition assembly should come with them, a Honda dealer should have them, online parts dealers might have them, especially Majestic Honda. Just cut the slots little by little until you can get a good grab with the screwdriver. That's the only way you'd be able to reuse them.
RE: how to remove an old ignition switch to replace it - 5/27/2008 11:12:57 PM
DA KID RYU
alright i really really thank u... cause i bout a use ignition from a member..
