loud noise when accelerating
  Printable Version
Honda Accord >> General >> General Tech Help >> loud noise when accelerating Page: [1] 2   next >   >>
Login
loud noise when accelerating - 10/27/2008 2:37:41 PM
stevenb17
Status: offline
i have a ''00 Accord and when i accelerate and the pedal is in the right spot i hear a loud chirping or whistling kind of noise. any idea''s of what that could be?
Post #: 1
RE: loud noise when accelerating - 10/27/2008 3:34:28 PM
falkore24
Status: offline
falkore24's photo gallery
CAI?
_____________________________
2006 Scion TC (ZPI-18G pending)
2000 V6-AT (RIP 3G)
Temp Search thanks to Finch13
(in reply to stevenb17)
Post #: 2
RE: loud noise when accelerating - 10/27/2008 4:18:40 PM
stevenb17
Status: offline
i just installed a SRI but it was happening before i put it in. it only got louder after i installed it...
(in reply to falkore24)
Post #: 3
RE: loud noise when accelerating - 10/27/2008 8:46:27 PM
patrickz
Status: offline
it could be the air getting sucked in. a sri changes the sound of ur engine. especially under hard acceleration. to check, start ur car with the hood open, have him rev it up and down, and put ur hea near the end of the intake
-it is what makes us different, that brings us together-
1996 accord 25th anniversary no vtec
Post #: 4
RE: loud noise when accelerating - 10/27/2008 8:56:45 PM
cjdm98
Status: offline
cjdm98's photo gallery
I would inspect all intake hoses, Vacuum,throttle,etc..
>>Click here to see my Accord<<
(in reply to patrickz)
Post #: 5
RE: loud noise when accelerating - 10/28/2008 6:56:33 AM
falkore24
Status: offline
x2 on vacuum connections .... also look at exhaust gaskets for black carbon indicating leakage.
2000 V6-AT (RIP 3G)
(in reply to cjdm98)
Post #: 6
RE: loud noise when accelerating - 10/28/2008 2:25:33 PM
stevenb17
Status: offline
i know it''s not the intake itself becuase it was happening before i put it in. i''ll make sure to check everything though.
Post #: 7
RE: loud noise when accelerating - 10/28/2008 3:26:16 PM
Hobbin
Status: offline
Guys I''ve been procrastinating on posting about the EXACT same problem.
I''ve been dealing with this high pitched noise for several several months, trying to figure out what it is.
My CAI definitely makes a noise, but it''s not the noise I''m talking about. I would describe the CAI noise as a "whistle," where I would call this unknown noise a high pitched "squeal."
Now I''ve heard loose belts squealing before, and it sounds nothing like this. Just to make sure it''s not a belt, I''ve put pressure on the belts that are visible to see if I can induce the noise or cut it out. Nothing happens. I tried to figure out how to loosen the tension on the timing belt then bringing it back to normal....but I ended up cancelling that mini-project in fear of ''messin up big time''. I don''t think it''s the timing belt anyways.
What it DOES sound like is a squealing bearing. My first thought when I heard the noise was "Oh, my throwout bearing is going bad." When I found out automatics dont even have that, I lol''d @ my stupidity.
No particular action will induce the squeal, except for when pressure is put on the engine. I mean, when the engine moves. When I pop it into gear from neutral, it squeals like crazy. SOmetimes worse than others. This is what made me think it was something to do with my transmission (since it sounded like a bearing, I assumed throw out bearing). After some studying and messing with it, I found that when I pop it into gear, the engine will move back a little bit, thus causing the squeal. So if it''s in neutral and not moving, I can push on the block with my hands (when not hot) and I can induce the squeal.
HAF, what are some steps I can take to help me fix this problem?!
**for the record, I do have a small exhaust leak between my headers and exhaust manifold. I don''t think this is the problem though, because the squeal sounds like metal against metal, not a "whistle" sound
If you plan on being original, plan on being copied
Owner of "The Battleship"
NGK iridiums, Struts, Sways & tie brace, CAI, AND A NEW BATTERY
+nice deck && subwoof+speakers+2amps
quote:
ORIGINAL: finch13
I don''t know what Hobbin is smoki
Post #: 8
RE: loud noise when accelerating - 10/28/2008 4:04:34 PM
falkore24
Status: offline
hmmm .... bearing/pulley in the alternator or power steering pump?
2000 V6-AT (RIP 3G)
(in reply to Hobbin)
Post #: 9
RE: loud noise when accelerating - 10/28/2008 6:08:17 PM
stevenb17
Status: offline
with mine it''s not when i put it into gear it''s when im accelerating and it only happens when the pedal is in the right spot. if i give it more gas the sound goes away and if i take off a little gas it goes away. it''s deffinately not the intake. it''s a completely different sound. it''s hard to explain what it sounds like other than a chirping kind of noise.
Post #: 10
RE: loud noise when accelerating - 10/28/2008 6:52:22 PM
cjdm98
Status: offline
Have you had someone in the driver seat press the gas and you listen to the engine? To pin point where the noise is coming from, once you know where,then you go from there.
Post #: 11
RE: loud noise when accelerating - 10/28/2008 7:16:20 PM
falkore24
Status: offline
Maybe a dirty throttle plate?
2000 V6-AT (RIP 3G)
Post #: 12
RE: loud noise when accelerating - 10/28/2008 7:31:01 PM
madsteez
Status: offline
It has to be vacum lines,or anything to do with the induction of air. No other part,bearing,belt would make the type of noise you are describing at and only at a particular rpm.
Post #: 13
RE: loud noise when accelerating - 10/28/2008 7:33:08 PM
patrickz
Status: offline
so it did it befor?
does it affect ur performance? and is it messing up ur engine in any way??
(in reply to madsteez)
Post #: 14
RE: loud noise when accelerating - 10/28/2008 8:06:33 PM
falkore24
Status: offline
Madsteez:  I wouldn''t rule out anything from a description.  Who''s to say that it isn''t a wheel bearing and he''s not hearing it from the right place?  I think that you are most likely right, but it does not HAVE to be a leak.
2000 V6-AT (RIP 3G)
Post #: 15
Honda Accord Forum >> General >> General Tech Help
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
wheelbrokera7085
sir_nasty6309
falkore245945
finch134299
00accordlx5s3815
deserthonda3575
live2rice3448
jimblake3281
19accord973171
smaglik2623
New Vendors
Sportwing
