RE: AIR INTAKES,WHY?
  Printable Version
Honda Accord Forums >> Your Ride >> Headers, Intake, & Exhaust >> RE: AIR INTAKES,WHY? Page: <<   < prev  1 2 [3] 4 5   next >   >>
Login
RE: AIR INTAKES,WHY? - 5/19/2005 11:45:58 AM
6thgen
Status: offline
6thgen's photo gallery
quote:
ORIGINAL: nrangerfan
Hot thread Gentlemen: I think I will start with teh AEM V2 Right away, as a reward for doing the belts, FuZion HRi's are in the mail - is there any greater anticipation than waiting for parts? Essencially it sounds like headers, exhaust intake is nice, but really all that work is prep for the installation of a turbo - True? If I were to look at a turbo down the line is there any ENGINE mods I'd need to make outside of what is listed above?
A header would have to to be removed for turbo and a turbo manifold would be installed in it's place. Mods are intended for the goal of the engine. Such as an exhaust for turbo is different than an exhaust for an N/A car. An intake would also be removed and a different intake would be needed for the turbo.
EDIT: Also, builing an engine is often suggested. Please view the link in the "GOOD TURBO INFO" thread for more on building engines. $$$$$$
_____________________________
The car is looking for a turbine...
(in reply to nrangerfan)
Post #: 31
RE: AIR INTAKES,WHY? - 5/19/2005 11:49:38 AM
6thgen
Status: offline
quote:
ORIGINAL: mega502
"200dry shot onto a stock motor"
Speaking of Gas mileage.
I'm truly a novice at modifing cars, shoot I just installed my first set of Ignition wires on the 1991 accord and my mpg shot up from 23.5 to 26.04mpg. I was impressed by the change, going to flip out the rotor and cap this weekend.
Thanks,
Doug
From another "true novice" A: what are the ignition wires, rotor and cap?
B: What does changing them out do for me? (you sparked my interest)
C: What does it cost?
Thing sin your ignition system get old and need replaced because they are not as efficient as they used to be ignition wires are the wires that connect the spark plugs to the distrutor cap. The cap has a rotor in it which sends the spark through the wires to the plugs and therefore causes combustion. Changing them is maintenance more than modification. Wires can go from $30-90 depending ont he wires and what type of ignition and engine they're for.
Post #: 32
RE: AIR INTAKES,WHY? - 5/19/2005 12:27:24 PM
habeel
Status: offline
I noticed a positive change when I replaced my ignition leads and spark plugs, however my cars mileage was high and had stock leads and plugs.
some companies claim thier leads and plugs can free up a little BHP, but i dont really believe it-
(in reply to 6thgen)
Post #: 33
RE: AIR INTAKES,WHY? - 5/19/2005 1:20:17 PM
6thgen
Status: offline
They replacing things like they do nothing but restore lost hp. If you added new oem plugs you'd feel the same results.
(in reply to habeel)
Post #: 34
RE: AIR INTAKES,WHY? - 5/19/2005 3:58:34 PM
jayhova804
Status: offline
jayhova804's photo gallery
If you plan on turboing defiantly dont waste money on headers an intake is a bit cheaper and id spend the money on one now even if i planned to turbo Another good mod is a grounding kit it doesnt add any horsepower but it frees up existing HP thats been lost over the years do to normal wear and tear on the electronics of the car.
BANNED
Post #: 35
RE: AIR INTAKES,WHY? - 5/19/2005 4:09:00 PM
6thgen
Status: offline
Some grounding kits, w/ voltage regulators are better a little better. A'pexi had the best dyno number in a test conducted by one of the magazines. Can't remeber which one. Hondas generally have good stock grounding, but it'll help anyway. Don't start looking for 10hp though. Plus you'll get better results from a grounding kit w/ a turbo...since you won't have to remove it.
(in reply to jayhova804)
Post #: 36
RE: AIR INTAKES,WHY? - 6/10/2005 5:16:36 PM
accordlowered04
Status: offline
accordlowered04's photo gallery
i see the cold air intakes on ebay. are they worth the money and will they make any kind of difference? or would they basically be a waste of money?
1991 Honda Accord
www.animatedimages.org
(in reply to mega502)
Post #: 37
RE: AIR INTAKES,WHY? - 6/10/2005 5:37:50 PM
6thgen
Status: offline
They're not a waste...the only difference between ebay and AEM or Injen is that they actually had R&D for the applications and some are DOT approved. Other than that they're all just a damn pipe that flows better than what the factory put on there...and sounds sweeter too. You may get a 1hp difference between intakes..if any at all.
(in reply to accordlowered04)
Post #: 38
RE: AIR INTAKES,WHY? - 6/11/2005 10:55:39 PM
boosted
Status: offline
quote:
ORIGINAL: CivicEX
I thought that they do give you better milage if you drive normal but if you start flooring it then your mpg will go down.
thats because the air intakes are designed to maximize airflow in ur intake manifold. if u run the piss outa your car, the gas MPG goes down... because the ECU has to balance out the fuel/air ratio. if your gettin more air.. you need more fuel to balance it out.. or else your cars gona not function properly
(in reply to CivicEX)
Post #: 39
RE: AIR INTAKES,WHY? - 6/12/2005 12:05:20 PM
6thgen
Status: offline
quote:
ORIGINAL: boosted
quote:
ORIGINAL: CivicEX
Good answer.
(in reply to boosted)
Post #: 40
RE: AIR INTAKES,WHY? - 6/12/2005 5:58:07 PM
Patrick
Status: offline
if i havent stated before, i have an "ebay intake" on my car...and with a K&N filter hooked to it instead of the cheap paper filter, it is every bit as good as the AEM unit, which costs 175-200 bucks more.
Post #: 41
RE: AIR INTAKES,WHY? - 10/2/2005 1:30:55 AM
billcat
Status: offline
I would tend to disagree depending on what type of change you did to the intake.
If you have it set up in any type of ram air or more freeflowing the car will see the increase and adapt to it to keep it from going lean so it will increase the gas flow to match it. You see more power but probably less gas mileage. Changing the temp of the air while keeping the flow the same may increase the gas mileage.
If all your after is better gas mileage changing to synthetic oil in both engine and trans, and cold air intake (maybe) and a better exaust system is about what you want to do. There are other ways also like different type tires.
Post #: 42
RE: AIR INTAKES,WHY? - 10/3/2005 10:59:01 AM
Shocker
Status: offline
I bought a full CAI off ebay seems to be great as far as ga mileage i dunno if it increased or helped but if u want better fuel economy running like supreme rather then regular will help you get more mileage you pay a little more but u get bettere mileage
Post #: 43
RE: AIR INTAKES,WHY? - 10/5/2005 4:34:04 PM
6thgen
Status: offline
The gains between the two aren't worth the price difference, unless your squeezing for hp that hard and have the funds to dish out. Be proud.
(in reply to Shocker)
Post #: 44
RE: AIR INTAKES,WHY? - 10/5/2005 4:34:17 PM
6thgen
Status: offline
The filter is more important than a pipe.
< Message edited by 6thgen -- 10/5/2005 4:35:15 PM >
Post #: 45
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
wheelbrokera6763
sir_nasty6303
falkore245545
00accordlx5s3797
deserthonda3568
19accord973117
jimblake3082
finch133007
smaglik2594
live2rice2406
New Vendors
Sportwing
