RE: CV Joints or Brakes rubbing?
Login | |
RE: CV Joints or Brakes rubbing? - 3/4/2008 4:14:55 AM
oma93
I'm not talking about reman or rebuilt. All of the parts stores sell brand new ones too. They are much better than rebuilt and are not much more money. If a boot has a hole in it, not only did grease come out, but contaminants got in. The only way to ensure that it won't fail due to that is to take the joint completely apart, thoroughly clean everything, reassemle it, put in new grease and install a new boot. That will cost a lot more than a new shaft. Just putting a new boot on is begging for problems in the near future.
_____________________________
93 Accord LX 4Dr 2.2EFI MT 210K Miles 32MPG mostly short trip in-town driving.
RE: CV Joints or Brakes rubbing? - 3/4/2008 6:19:58 AM
pwr
I have been through a lot of half shafts and I've done it every possible way: new boots, reman half shafts, new half shafts. Though they're the cheapest option, I have had no luck with reman units. You don't get a fraction of the life out of them. New is good, but expensive. If you've gotten to 120K miles on the original boots, they don't owe you anything. It's worth the trouble to pull them and replace them so you don't have to give up the OEM joints. I got my Legend to 240,000 miles on the original joints. They clacked a little bit at the end when I unloaded and then loaded them, but they were still smooth. OTOH, I went through two sets of reman half shafts on my Integra in only 180,000 miles. Totally unpredictable wear. I maintain my rides for the long haul. My rule of thumb: at 120K (or when they start to crack), replace the boots. If they've already split, go with new, not remanufactured units.
PHIL in MOTOWN 2002 Accord EXL Cpe F23 5sp 1995 Del Sol Si 5sp Past: 1993 Accord LX 5sp 1989 Acura Legend 1987 Acura Integra 1986 Honda CRX Si 1983 Honda Civic S 1972 BMW 2002 tii 1967 Mustang GT Fastback 1959 Austin Healey Sprite
RE: CV Joints or Brakes rubbing? - 3/4/2008 11:02:19 AM
oma93
quote:
ORIGINAL: pwr I have been through a lot of half shafts and I've done it every possible way: new boots, reman half shafts, new half shafts. Though they're the cheapest option, I have had no luck with reman units. You don't get a fraction of the life out of them. New is good, but expensive. If you've gotten to 120K miles on the original boots, they don't owe you anything. It's worth the trouble to pull them and replace them so you don't have to give up the OEM joints. I got my Legend to 240,000 miles on the original joints. They clacked a little bit at the end when I unloaded and then loaded them, but they were still smooth. OTOH, I went through two sets of reman half shafts on my Integra in only 180,000 miles. Totally unpredictable wear. I maintain my rides for the long haul. My rule of thumb: at 120K (or when they start to crack), replace the boots. If they've already split, go with new, not remanufactured units. Yep, what pwr says. If you have no noise in them and they are cracking but not open then replacing the boots and grease is the way to go. If they are opened cracks, even a little, or they are making any noise at all, replace the shaft. And I agree about reman or rebuilt, if you only plan on 50K miles before junking or selling, then reman would do I suppose. If you plan on keeping it then only go with new.
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Honda Accord Prices
Advertising Info
Contact Us |
Advertising |
Automotive Links |
Archive |
About Us |
Honda Accord Links |
Legal |
Privacy Policy |
© Honda Accord Forum.com
