RE: Strut and Sway Bars
Login | |
RE: Strut and Sway Bars - 4/3/2008 1:03:06 PM
atarikid07
Oh sorry about the misunderstanding. I totally understand falkore's pic. I meant in my post with both Neuspeed things. Those are both front strut bars right? Which would you guys suggest getting, cause they are two different designs, but one is about $60 less...
_____________________________
2000 Accord EX V6 - K&N Short Ram Intake - Pioneer DEH-P6000UB - Blue Courtesy and Dome LEDs
RE: Strut and Sway Bars - 4/3/2008 2:39:55 PM
sir_nasty
The Neuspeed picture is to small to tell exactly what it is....Kind of a funky design if it is a sturt tower bar... the Tenzo is a strut tower bar for sure.... I bought a $60.00 solid billet aluminum no-name one from my local parts shop and it made a noticeable difference.... the biggest thing you need/want is Solid core (no hollow crap) and good contstruction/welds on the pieces that mount to the towers, if you find those things then names make no difference.
1981 Civic Station Wagon - ROhnda (Really Old Honda) 1981 Honda CB650 Motorcylce - WHEE What More can I say? 2000 Lexus RX 300 - Oooh baby my wife let me drive it once!! Quote: Life''''s great but it''''s not all beer and skittles
RE: Strut and Sway Bars - 4/3/2008 4:55:15 PM
sir_nasty
It looks like a very nice design actually.... it would appear that rather than having a plate on each side with a bar it bolts the bars straight to the towers then ties them all in which should make it very hard to twist (which is what you want)... Never seen that before but I love the concept, it seems sound in theory.... no brakets and junk...
RE: Strut and Sway Bars - 4/3/2008 6:05:21 PM
falkore24
A friend had that bar in the poluished finish ... it's a nice bar.
2006 Scion TC (ZPI-18G pending) 2000 V6-AT (RIP 3G) Temp Search thanks to Finch13
RE: Strut and Sway Bars - 4/5/2008 4:52:58 PM
JohnL
quote:
ORIGINAL: sir_nasty Sway bar (aka anti-sway bar): In the simplest of explinations when you corner the body rolls to the outside because of centrifical force. When it does this the natural order of things is to start lifting the inside tire up so it has less contact with the road. A sway bar tries to push that inside tire back down when the outside tire goes down. Not meaning to be picky, but the affect is opposite to your description. The ARB (anti-roll bar / sway bar / anti-sway bar...) increases 'lift' affect at the inside wheel, not "tries to push that inside tire back down when the outside tire goes down" (whatever this statement means, as it seems a bit self contradictory). Assuming lateral acceleration, and thus total lateral weight transfer remains the same (i.e. the sum of front + rear weight transfer remains constant), if the stiffness of a single ARB is increased then the amount of lateral weight transfer will be increased at the end of the car at which ARB stiffness has been increased, and weight transfer at the other end will be equally reduced. Assuming no change in lateral 'G' force, the sum total of lateral weight transfer (front + rear) will remain the same, but the distribution of that transfer (front vs rear) will change. This is why (e.g.) increasing the front ARB stiffness tends to increase understeer, i.e. more weight transfers from the IF to the OF, but also equally less weight transfers from the IR to the OR. This moves the grip balance toward the rear, i.e. more equally distributed rear weight, and less equally distibuted front weight, which in effect equates to more 'rubber on the road' at the rear than the front, thus more understeer / less oversteer (with an increase in front roll stiffness). Of course the opposite affect will occur with a rear ARB stiffness increase (or reduction in front ARB stiffness) If front and rear ARB stiffness were increased equally then the grip balance would remain the same and the understeer / oversteer balance would be unchanged. What would change is the degree of roll (lessened) and the the general steering and handling responsiveness (increased). In this case there would be no change in the 'lifting' affect at either of the inside wheels, the degree of weight transfer would remain the same (assuming no increase in 'G' force, which will probably change), though the speed at which the weight transfer occurred would be faster (hence more responsive handling characteristics).
< Message edited by JohnL -- 4/5/2008 5:00:02 PM >
RE: Strut and Sway Bars - 4/5/2008 5:39:12 PM
JohnL
quote:
ORIGINAL: sir_nasty the biggest thing you need/want is Solid core (no hollow crap) The tower brace's 'bar' being tubular isn't really an issue as long as the tube OD and wall thickness is great enough for the bar to be adequately rigid in compression (i.e. a strong compressive force doesn't cause the bar to 'bow' under load). For tower braces where the bar is not bent in any way a tubular bar is usually adequate, but as soon as a bend is placed in the bar it becomes much weakened in both compression and tension, so solid would be better as would much larger external dimensions. Note also that bars that have a flattened bar section / shape tend to be weaker in compression (and tension if a bent bar). quote:
and good contstruction/welds on the pieces that mount to the towers, if you find those things then names make no difference. Agreed, but more important even than nice welds etc is that the attachment brackets are substantially rigid. If the metal from which the brackets are made is too thin or the bracket not well braced within it's design (providing a rigid load path from the ends of the brace bar to the tops of the 'strut' tower), then the brace is weak regardless of how rigid the bar itself may be. I would suggest that the bracket material should be at least 4mm - 5mm thick, and braced from the top of the bracket as directly as possible to as much as possible of the 'strut' tower top.
RE: Strut and Sway Bars - 4/5/2008 7:31:30 PM
steve123
so about the sway bars which do u guys prefer? TANABE or ST SUSPENSIONS?
1997 honda accord 4 dr LX auto stock
RE: Strut and Sway Bars - 4/5/2008 7:50:37 PM
falkore24
I loved my Comptechs. Progress also makes an excellent product. I think that Tanabe and ST are the same company, but I might be wrong. I know that they make good strut bars, but I don't have any experiance with their sways.
RE: Strut and Sway Bars - 4/5/2008 7:55:57 PM
steve123
Thats kool but i think tanabe and ST are the only suspension brand who make parts/ sway bars for 97 accords that I know of!
RE: Strut and Sway Bars - 4/5/2008 8:15:09 PM
steve123
kool! thanks! I'll try to find pics for that and see how it performs! I saw the ST installed on a 97 accord in the project car mag and since my cars green it would look nice! But then again i saw the tanabe's install on a 94 accord on project low key in modified mag and that looked kool as well! So i'm just debating on what is better!
RE: Strut and Sway Bars - 4/5/2008 8:43:47 PM
falkore24
You plan to buy a sway bar based on it's color? Good luck man...
RE: Strut and Sway Bars - 4/6/2008 2:22:34 AM
Drkmstr104
I bought front and rear strut bars, so far Ive installed the front and am working on the back, which are a bit tricky to get to. Got em from ebay, but I was very selective about them. The bars are made out of aluminum, the mounting pieces are made out of steel, the bar is thick, and I did notice a difference while driving, steering has become more responsive. Cost 45 bucks (shipping included) for both the front and rear, so yea Id say go for the ebay ones, just be on the lookout for ones that are thin because they will likely bow under high stress.
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Honda Accord Prices
Advertising Info
Contact Us |
Advertising |
Automotive Links |
Archive |
About Us |
Honda Accord Links |
Legal |
Privacy Policy |
© Honda Accord Forum.com
