RE: Smoking/Tinting Tail Lights
  Printable Version
Honda Accord Forums >> Your Ride >> Appearance >> RE: Smoking/Tinting Tail Lights Page: <<   < prev  1 2 [3] 4   next >   >>
Login
RE: Smoking/Tinting Tail Lights - 5/6/2008 9:16:49 PM
finch13
Status: online
quote:
ORIGINAL: 19Accord97
Do you guys think it would look stupid if I blacked out my corner pieces next to the headlights?
I've seen it done a lot of times, BUT the turn signal bulbs aren't very bright as it is and upgrading turn signals to LEDs would be a PITA.
EDIT: You could get the JDM blackhoused corners...
< Message edited by finch13 -- 5/6/2008 9:17:12 PM >
_____________________________
-> USE ME TO SEARCH HAF <-
1999 Accord LX F23A1 5MT
(in reply to 19Accord97)
Post #: 31
RE: Smoking/Tinting Tail Lights - 5/7/2008 6:14:47 AM
falkore24
Status: online
falkore24's photo gallery
Film tint is meant for the inside of the window.
2006 Scion TC (ZPI-18G pending)
2000 V6-AT (RIP 3G)
Temp Search thanks to Finch13
(in reply to finch13)
Post #: 32
RE: Smoking/Tinting Tail Lights - 5/7/2008 7:16:48 AM
HustLa
Status: offline
HustLa's photo gallery
Is it bad to just use black paint instead of this night shade stuff? I mean th transparency won't bother me because I don't want to paint over everything. I want to try something like this image, but I'm not sure if I can just use paint or if I have to use the other thing.
< Message edited by HustLa -- 5/7/2008 7:18:41 AM >
Post #: 33
RE: Smoking/Tinting Tail Lights - 5/11/2008 2:27:27 PM
HustLa
Status: offline
I ended up doing it haha.
[Image]http://i209.photobucket.com/albums/bb283/Scadoodly/yea.png[/Image]
1998 Honda Accord EX V6
(in reply to HustLa)
Post #: 34
RE: Smoking/Tinting Tail Lights - 5/11/2008 2:31:56 PM
19Accord97
Status: offline
19Accord97's photo gallery
Looks nice!
What was the process you used?
*Quit
Later
Post #: 35
RE: Smoking/Tinting Tail Lights - 5/11/2008 2:36:34 PM
HustLa
Status: offline
I removed the taillight. Used spray paint. 2 coats primer, 3 coats black paint, 2 coats of clear coat and let it dry about a day
Edit: I forgot to mention that I used clear red tape to put over the parts I didnt want painted and used a razor blade to shape it.
< Message edited by HustLa -- 5/11/2008 2:41:02 PM >
Post #: 36
RE: Smoking/Tinting Tail Lights - 5/12/2008 9:31:14 AM
donpisto
Status: offline
I was never a fan of the long red piece on the coupe.  I like whta you did, looks MUCH better IMO.  I'll be spraying my tails once I get them. I'm also going to replace pretty much all the bulbs.  Going to go with LED bulbs where I can.
As for the headlights, the projector lights I have, have a bit of blue for the circular part (like when you see BMW's from behind).  My headlights are white, maybe a faint of yellow in there and I don't like that.  I'd like for them to blend better. Perhaps a white/blue.   I forgot where I saw it, but people recommended a certain type of bulb from Sylavnia.  Is that what I should stick with or something else?  If I should stick with the Sylvania, which type do I get?  I've noticed there are their high performance bulbs and some other ones, so I'm not sure which one I would need.
Post #: 37
RE: Smoking/Tinting Tail Lights - 5/12/2008 9:59:59 AM
falkore24
Status: online
Just a heads up ..... LED's in the reverse lights look cool, but don't put out as much light ...... might want to consider sticking with bulbs there.
2000 V6-AT (RIP 3G)
(in reply to donpisto)
Post #: 38
RE: Smoking/Tinting Tail Lights - 5/12/2008 10:20:38 AM
finch13
Status: online
Sylvania makes Silverstar and Silverstar ULTRA bulbs that are a bit whiter and brighter than regular halogens. DDMTuning also makes a relatively cheap ($150) HID kit in a range of temperatures.
Post #: 39
RE: Smoking/Tinting Tail Lights - 5/12/2008 11:16:31 AM
donpisto
Status: offline
quote:
ORIGINAL: falkore24
Hmmm, I would have thought they would put out more light.  I was thinking about replacing all the tail light bulbs with LED's and also the front turn signal.  In all cases would it be not as bright?
quote:
ORIGINAL: finch13
Thanks for the info. If I hadn't bought the headlights I have I probably would go with the HID kit.  Just gotta get me some of the bulbs you mentioned tho.
(in reply to falkore24)
Post #: 40
RE: Smoking/Tinting Tail Lights - 5/12/2008 1:18:00 PM
falkore24
Status: online
LED's are more intense than bulbs, so they create a brighter point source of light.  The total light output is less than the bulb though.
2000 V6-AT (RIP 3G)
Post #: 41
RE: Smoking/Tinting Tail Lights - 5/12/2008 4:23:55 PM
donpisto
Status: offline
Ah, gotcha. Thanks for the clarification. I bet I'm not the only one who thought LED's were brighter
Post #: 42
RE: Smoking/Tinting Tail Lights - 5/12/2008 6:31:03 PM
finch13
Status: online
quote:
ORIGINAL: donpisto
quote:
ORIGINAL: finch13
You can still get HIDs, they have numerous bulb sizes. falkore had HIDs in his stock housing, they were legit.
Post #: 43
RE: Smoking/Tinting Tail Lights - 5/12/2008 6:32:23 PM
finch13
Status: online
quote:
ORIGINAL: falkore24
Even those 30 LED bulbs? If you set up an array in there it could potentially be brighter than filament.
Post #: 44
RE: Smoking/Tinting Tail Lights - 5/13/2008 7:36:31 AM
falkore24
Status: online
quote:
ORIGINAL: finch13
I'm just going by the things that I've read and pictures that I've seen.  I think the swap on tC's is usually a 5 LED cluster, but I may be wrong.  A massive array like you mentioned may be brighter, but will it fit the housing?
I thought that LED's would be brighter too and had done this research because I had planned on doing the swap as well.  I think I'm going to see if I can find ceramic sockets so I can run 50W bulbs ..... I have to back into my parking spot at night and it's very dark behind me.
2000 V6-AT (RIP 3G)
Post #: 45
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
wheelbrokera6817
sir_nasty6303
falkore245594
00accordlx5s3797
deserthonda3574
19accord973125
finch133120
jimblake3116
smaglik2594
live2rice2495
New Vendors
Sportwing
