RE: eBay Intake
Login | |
RE: eBay Intake - 5/14/2008 11:48:10 AM
falkore24
Nope, the bumper isn't hard to take off though. Just a few screws and clips. the easiest way to deal with the clips that I've found is to pry the inner piece up a little with 2 small flat screwdrivers and then use a pair of needle nosed pliers to pull it the rest of the way out. Note that the pliers aren't used for squeezing, but rather like a pickle fork to lift using the sides. On my brother's CL, I got it out with only removing the bumper half way and the lower shield, but it was a lot easier to just take the bumper off.
_____________________________
2006 Scion TC (ZPI-18G pending) 2000 V6-AT (RIP 3G) Temp Search thanks to Finch13
RE: eBay Intake - 5/14/2008 11:50:29 AM
00AccordLX5spd
you will have to remove the bumper unless you cut the resonator out in pieces (probably more trouble than removing the bumper.)
2000 Accord LX Sedan F23A1 5spd -Short Shift Adapter -eBay SRI w/ K&N 1995 Accord V6 Sedan AT - AKA "the money pit" 1991 Mustang LX 5.0 Convertible - my daily driver all through college - now sits in my dad''s garage - needs a little TLC
RE: eBay Intake - 5/14/2008 10:46:05 PM
coup de grace
Ok I have everything installed. I had to make a lot of adjustments, the Bomz filter didn't fit my Accord exactly. Since I needed to buy some push screws for my bumper, I went and converted the CAI to a SRI for a short while. But eventually, I got the splash guard, bumper, resonator off. Here are photos of the final installation: Now cosmetically, everything looks OK (to me). However it appears I've run into some issues. First of all, my check engine light came on. Second of all, when I'm flooring the engine, I'm hitting 5000+RPM but I'm catching almost no speed. I can definitely hear the new intake, but my acceleration is noticebly slower. Any idea what's wrong?
2002 Honda Accord V6 EX Sedan Bomz Cold Air Intake w/AEM Dryflow NGK Iridium IX Spark Plugs EuroDezigns 6000K High/Low Beams Black Altezza Tailights
RE: eBay Intake - 5/15/2008 9:52:31 AM
KevinAccord
go to pepboys or autozone ect, and get them to check your car w/ the computer they have, it probably has something to do w/ the MAF being taken out and putting it back in... after they fix that, you should have no problem. Other fact could be an excess of air in the cylinder???? don't think so but sounds like a fuel/air mixture problem... but I can't tell by the info you gave... Put more details and ill do my best to help you bro...
2000 Accord LX i4 Turbo AT 18" Konig Unknown Rims MSD 6AL Gold Line Suspension Apexi Neo Few other Mods... Mini Cooper 2006 MT HID's 17" Rims Premium Package Sport Suspension Short Shifter Panoramic Sunroof Stock Engine (For
Contact Us |
Advertising |
Automotive Links |
Archive |
About Us |
Honda Accord Links |
Legal |
Privacy Policy |
© Honda Accord Forum.com
