RE: Please help Honda Accord 99ex
Login | |
RE: Please help Honda Accord 99ex - 5/13/2008 7:55:02 AM
00AccordLX5spd
I thought about the main Relay, but i didn't think it was very typical of the main relay to cause the car to die while driving. Do a search on the forum for "Main Relay" or "Main Fuel Relay." Is it hot where you are? Does the problem seem to be worse when it is hot (or has been hot) inside the car?
_____________________________
2000 Accord LX Sedan F23A1 5spd -Short Shift Adapter -eBay SRI w/ K&N 1995 Accord V6 Sedan AT - AKA "the money pit" 1991 Mustang LX 5.0 Convertible - my daily driver all through college - now sits in my dad''s garage - needs a little TLC
RE: Please help Honda Accord 99ex - 5/13/2008 1:40:43 PM
blkhonda1999ex
no not that hot, im in northern california. today during my lunch time, the car died again and i was stuck at the parking lot and not even park. luckily people were nice enough to not say anything. i was going to push the car but i cant put the shift to neutral from park. why is that?
RE: Please help Honda Accord 99ex - 5/13/2008 2:32:40 PM
PAhonda
That is the shift lock system. The ignition switch controlis the interlock system. From your description of the car stalling while driving and now the interlock system, I would replace the electrical part of the ignition switch.
1995 Accord EX MT
RE: Please help Honda Accord 99ex - 5/13/2008 2:40:06 PM
00AccordLX5spd
Have you tried the "key wiggle" test I suggested? FYI: # 10 is the switch hondaed posted the part # earlier
< Message edited by 00AccordLX5spd -- 5/13/2008 2:45:16 PM >
RE: Please help Honda Accord 99ex - 5/13/2008 3:01:39 PM
blkhonda1999ex
quote:
ORIGINAL: PAhonda That is the shift lock system. The ignition switch controlis the interlock system. From your description of the car stalling while driving and now the interlock system, I would replace the electrical part of the ignition switch. if i replace the electrical part? will my interlock be fix?
RE: Please help Honda Accord 99ex - 5/15/2008 11:28:29 PM
deserthonda
quote:
ORIGINAL: 00AccordLX5spd I thought about the main Relay, but i didn't think it was very typical of the main relay to cause the car to die while driving. I agree with you ooaccord .... i have done dozens and dozens and dozens of main relays,, resolder and replace ,,and NOT ONCE ,, has the main relay killed the engine while driving ..common cause of a bad main relay is a failure to start the car when ambient temp is hot or very humid .. Have you checked if the ign switch recall has been done ?? like it was adviced ??? after car dies ,, chk to see if engine is getting fuel.. if it is,,, most likely it is not the main relay Also contrary to members advicing you to start replacing parts,, I would not start replacing part until you properly DIAGNOSE the problem....
No Year No Model in Your signature No Help from me Take a look in the DIY section before asking for help Always Diagnose First,,, Before Replacing Parts
RE: Please help Honda Accord 99ex - 5/16/2008 5:49:19 AM
JimBlake
quote:
ORIGINAL: blkhonda1999ex ed, i tried the wiggle test but the car did not stall. i also tried putting the key to on (not start) and i didn't hear any noise in the back for fuel pump. i guess next step is main relay. That wiggle-test is kinda one-sided. If you can get it to stall by wiggling the key, then the electrical part of the ignition switch is the culprit. But if it doesn't stall, that does NOT prove the switch is OK. It just means you haven't yet found the right position to get it to screw up.
'03 Accord & '07 Civic '01 Saab 9³ & '05 9²x
RE: Please help Honda Accord 99ex - 5/16/2008 7:52:29 AM
00AccordLX5spd
quote:
ORIGINAL: deserthonda Have you checked if the ign switch recall has been done ?? like it was adviced ??? quote:
ORIGINAL: blkhonda1999ex I called Honda and I asked them about the ignition recall and unfortunately my vin# was not included to the recall. yeah he checked with Honda. I agree with you Desert. I would not recommend him replacing any parts just yet. He needs to do some more testing of the ignition components. I do not know how to test this, so I'll leave that up to someone that is smarter than me . Is there any way to test that without buying tools that may cost as much or more than buying the replacement part? That is usually where I draw the line. If I have a very good idea that I know what part is bad and the part is not expensive, sometimes I will replace. But that is only if I am DIYing as well. But again, I DO NOT recommend throwing parts at it if I am not at least 80% sure I know what part is causing my problem (and the part is cheap and would likely eventually need replacement anyway.
< Message edited by 00AccordLX5spd -- 5/16/2008 7:56:38 AM >
RE: Please help Honda Accord 99ex - 5/16/2008 1:19:29 PM
blkhonda1999ex
case closed! thanks guys! replaced the main relay and all is excellent!
RE: Please help Honda Accord 99ex - 5/16/2008 2:12:13 PM
00AccordLX5spd
Thanks for posting the fix. I am surprised..... I was sure thinking it was something in the ignition....oh well, you learn something new every day!
RE: Please help Honda Accord 99ex - 5/16/2008 4:32:27 PM
deserthonda
quote:
ORIGINAL: blkhonda1999ex case closed! thanks guys! replaced the main relay and all is excellent! UHMM I am very surprised as well that all is fixed.. hard to believe,, even the cannot get it out of park ??? it does not make any sense , main relay does not have anything to do with that
RE: Please help Honda Accord 99ex - 5/16/2008 5:51:02 PM
blkhonda1999ex
Why wouldn't it be fix? it's running excellent without stalling. My main relay was bad and was cutting off lines to my fuel so therefore the car often stall and when the car stall you wouln't be able to take the transmission out of park. You could if the car did not stall.
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Honda Accord Prices
Advertising Info
Contact Us |
Advertising |
Automotive Links |
Archive |
About Us |
Honda Accord Links |
Legal |
Privacy Policy |
© Honda Accord Forum.com
