RE: Turbo bought
Login | |
RE: Turbo bought - 4/5/2006 7:26:57 PM
marbro
welp, turbo piping 2 1/2inch, fmic 3inch core, greddy bov, turbosmart 38mm wastegate, boost controller, hoses and all the happy little screws, bov and wastegate gaskets,bov flange for $360 Already have: drag turbo manifold $355 t3/04 turbo $280 Need: 5 bolt Down pipe wastegate downpipe screws for turbo to manifold gasket for manifold to exhaust, turbo to manifold, turbo to downpipe, down pipe to cat boost meter a cute fuzzy kitten to blame when i find out the wastegate has a 15psi spring in it, and my engine blows. I think this one might be the most expensive piece......
RE: Turbo bought - 4/7/2006 5:33:55 PM
lightshow
marbro your cars going to be mean with a turbo...get ready
RE: Turbo bought - 4/7/2006 7:06:33 PM
sir_nasty
I want a turbo... :( ever since I heard that the f22 is great for turbos I've wanted one for my car...
RE: Turbo bought - 4/7/2006 9:52:33 PM
marbro
yeah, two main reasons why turbos are better for f series engines, first f engines have basically a 1 to 1 hp to ft lbs torque ratio and that transfers over when you run boost, to get that on an h series you have either change the crank, and or change the rods and pistons which brings me to number two, the h22 mentioned for swapping has no less then a 10:1 compression ratio which means you have to run less boost otherwise you will brow the engine, so if you want to run a lot of boost you have to change the pistons, and if you change the pistons you might as well change the rods as well, oh..... theres a third thing...... if you want you can run a lot of boost on the f series engine...... why? cause if you blow it they are cheaper then the h series lol actually had a friend recommend that to me but i want an engine thats strong and wont blow up on me lol
RE: Turbo bought - 4/8/2006 5:55:42 PM
SKHEMR
I forgot to mention the down pipe will hit if your car is lowered. If it's normal height you should be fine. I don't think civic's have that flex pipe on the down pipe like accords do. I believe you need that because of the length.
