RE: 5w20 and Oil change
Login | |
RE: 5w20 and Oil change - 5/16/2008 4:59:32 PM
Accord Owner
Am I hurting the car by changing every 3K miles?
RE: 5w20 and Oil change - 5/16/2008 5:36:14 PM
finch13
quote:
ORIGINAL: Accord Owner Am I hurting the car by changing every 3K miles? In what way could you possibly fathom harming a car by changing the most vital fluid more often?
_____________________________
USE ME TO SEARCH HAF PWOTY 2008!
RE: 5w20 and Oil change - 5/16/2008 5:55:49 PM
hondaed
I would like to add one other thing to the response about oil and leaving it in too long. I have included a couple of photos of an Acura NSX piston to reference The bottom groove of the piston is the oil control ring. As the piston moves up and down, this ring set wipes the excess oil from the cylinder wall. Once these rings wipe the excess oil, it has to go somewhere, so there are small holes in the piston for the oil to escape and drian back into the crankcase. Overtime, these holes get clogged and the oil has no where to go, so most of it gets to the combustion chamber and is burned. If you do not change your oil regularly, oil sludge can clog these holes and the heat generated at the piston will cook that oil into these holes. During engine overhauls, we have to drill through these burnt oil deposits. I have seen engines with over 200,000 miles with these holes as clean as the day the engine was assembled and I have also seen an Accord engine that only had about 30,000 miles, where the owner had not changed the oil EVER and the sludge had completely caked and cooked around this groove. Yes, he was burning oil. Ed Brian Accurate Automotive, inc. www.accuratecars.com Thumbnail Image
Thumbnail Image
Attachment (2)
RE: 5w20 and Oil change - 5/16/2008 6:04:22 PM
poff1986
****BUMP**** quote:
ORIGINAL: 19Accord97 quote:
ORIGINAL: Accord Owner Synthetic is junk according to my friend who has 30 years of experience in the car business. Stick to basics. Castrol GTX is what he recommends. 5K or 4 months? What if you drive 10K in 3 months? Well your friend is not the brightest crayon in the box....by far. If he has 30 years in car buisness and claims Synthetic is junk , I would NEVER let him touch my car or even remotely accept his advice. There is no way synthetic is junk. If so, why would Nascar, drag racing, and monster truck racing all use synthetic motor oil? Because they are driving hard, and need an oil that wont break down under high heat or wear away their $50k motors or so. Royal Purple is the best synthetic. But any other oil that is fully synthetic and a common brand will do just fine for normal driving. Synthetic lasts longer, and reduces friction inside your engine. Less friction = less wear, longer life for the oil itself, and better gas mileage and hp. As for "5K or 4 months? What if you drive 10K in 3 months?" It means 5k or 4 months. Whichever comes first.
SOHC VTEC
RE: 5w20 and Oil change - 5/16/2008 6:27:48 PM
Accord Owner
quote:
ORIGINAL: finch13 quote:
ORIGINAL: Accord Owner Am I hurting the car by changing every 3K miles? In what way could you possibly fathom harming a car by changing the most vital fluid more often? I was not sure
RE: 5w20 and Oil change - 5/23/2008 1:13:48 PM
erivkin10
Oil and oil filters are almost like politics and religion. Almost everyone has an opinion and there is no consensus. For what it's worth I've run Mobil 1 Synthetic in two cars since they were new. My usual daily drive is a 96 Volvo 850 MT with 159k miles on it. Oil consumption has increased to 1qt/1400 or so in the last 20-30k. I change the oil roughly every 5-6k or 5-6 months. The other vehicle is an 01 Honda Odyssey with 81k miles on it. Oil consumption remains less than a quart between the 5-6k oil changes. The Odyssey is my wife's car so I cannot validate any improvement in fuel economy from Mobil 1. I believe the Volvo mpg increased about 7-10% after switching to M1. Summer highway is still 31 and summer mixed around 25mpg. Most 850 owners that I know have AT's and use dino oil. The best mpg I've ever heard from them is about 27-28 summer highway. I can't comment about my Accord yet. I recently purchased an '06 I4 w/ MT. At the next oil change I intend to also use M1 and will for the rest of it's life.
Ed 1959 190SL 4 spd 1996 Volvo 850 GLT 5spd 1998 Acura CL 5spd 2001 Odyssey 2006 Accord EXL 5sp
RE: 5w20 and Oil change - 5/23/2008 2:06:42 PM
00AccordLX5spd
From my research. For most of our common daily driver applications, regular dino oil is just fine. Synthetic may be a waste of money. I use MaxLife Syn Blend because it is good oil and it is cheap ($12 for 5 quarts at Walmart). I didn't even realize it was syn blend till about my 3rd DIY oil change haha.
2000 Accord LX Sedan F23A1 5spd -Short Shift Adapter -eBay SRI w/ K&N 1995 Accord V6 Sedan AT - AKA "the money pit" 1991 Mustang LX 5.0 Convertible - my daily driver all through college - now sits in my dad''s garage - needs a little TLC
RE: 5w20 and Oil change - 5/27/2008 9:19:30 AM
falkore24
I just wanted to point out a few things: 1) Royal Purple - I too used to think that it is the best oil made. It does have some excellent properties, but over time, it can cause a graphite build-up that can cause engine damage. 2) Oil return ports - If you run a quart of Marvel Mystery Oil for about 1000 miles once a year, these will get cleaned out. 3) Engine Flush - Do this once a year maximum. Best time is following the 1000 miles with the MMO.
2006 Scion TC (ZPI-18G pending) 2000 V6-AT (RIP 3G) Temp Search thanks to Finch13
RE: 5w20 and Oil change - 5/31/2008 10:43:40 PM
Accord Owner
Castrol GTX recommends using the high mileage after 75K, is that ok?
RE: 5w20 and Oil change - 6/9/2008 8:54:48 PM
jackkpts
You did not say in the original post what year your Accord is. Do you have an oil life monitor? If so, watch the oil life levels and change at the 20% or 30% rating. If you''re going to change your oil every 3K to 5K miles, one of the best oils and best price performance oils is the Motorcraft 5w20. It''s a semi-synthetic and has received rave reviews on Bob''s the Oil Guy forums from users. One of the member''s companies ran a test on a number of oils and they found that this oil was the best of the semi-synthetics. You can find it at Walmart everyday for under $11K for 5 quarts. Top filters include Pure1 and Wix/Napa Gold, about $5 to $6.
Jackkamo 2006 Accord EXL 4cyl Automatic
RE: 5w20 and Oil change - 7/6/2008 2:34:55 PM
Accord Owner
quote:
ORIGINAL: jackkpts You did not say in the original post what year your Accord is. Do you have an oil life monitor? If so, watch the oil life levels and change at the 20% or 30% rating. If you''''re going to change your oil every 3K to 5K miles, one of the best oils and best price performance oils is the Motorcraft 5w20. It''''s a semi-synthetic and has received rave reviews on Bob''''s the Oil Guy forums from users. One of the member''''s companies ran a test on a number of oils and they found that this oil was the best of the semi-synthetics. You can find it at Walmart everyday for under $11K for 5 quarts. Top filters include Pure1 and Wix/Napa Gold, about $5 to $6. 2005. No oil life meter.
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Honda Accord Prices
Advertising Info
Contact Us |
Advertising |
Automotive Links |
Archive |
About Us |
Honda Accord Links |
Legal |
Privacy Policy |
© Honda Accord Forum.com
