RE: f22b2 or h22a
Login | |
RE: f22b2 or h22a - 5/26/2008 10:43:46 AM
legal
how much hp could i get by just turboing my f22? say at 10 or 15 psi? saw f22b2 with 10 psi keep up with a evo with 24 psi. im just really confused on what to do. i just want a quick car.
RE: f22b2 or h22a - 5/26/2008 6:04:02 PM
legal
hp goal would be 300. price doesnt matter. whats a good turbo to use? and how come you see more vtecs turbod then you do non
RE: f22b2 or h22a - 5/26/2008 9:34:46 PM
legal
thats cheesy. let me ask this then. what would you suggest a good hp goal is? daily driver. and how would i get it?
RE: f22b2 or h22a - 5/27/2008 8:00:12 AM
falkore24
For a DD with FWD, anything over 350HP isn't going to be usable ..... unless you just want to smoke tires until they explode. I'd recommend a turbo F22 with a micro-polished OEM crank, performance bushings, rods, pistons, rings, wrist pins and a turbo pushing 9 psi. I'd also get a 2 stage boost controller so you can switch to race mode and pump up the turbo to about 12.5 psi, but I'd keep it on the lower setting mostly.
_____________________________
2006 Scion TC (ZPI-18G pending) 2000 V6-AT (RIP 3G) Temp Search thanks to Finch13
RE: f22b2 or h22a - 5/27/2008 9:02:52 AM
legal
quote:
ORIGINAL: falkore24 For a DD with FWD, anything over 350HP isn't going to be usable ..... unless you just want to smoke tires until they explode. I'd recommend a turbo F22 with a micro-polished OEM crank, performance bushings, rods, pistons, rings, wrist pins and a turbo pushing 9 psi. I'd also get a 2 stage boost controller so you can switch to race mode and pump up the turbo to about 12.5 psi, but I'd keep it on the lower setting mostly. i like how that sounds any specific turbo? and where can i get all of this? websites? thanks for all your info dood
