RE: I need imediate help please
  Printable Version
Honda Accord >> General >> General Tech Help >> RE: I need imediate help please Page: <<   < prev  2 3 [4] 5 6   next >   >>
Login
RE: I need imediate help please - 6/11/2008 9:08:36 PM
JimBlake
Status: offline
Need_to_figure_out_why_the_red/black_wires_are_24v.  Thats_not_right_hope_its_bad_measurement.
For_testing_continuity_(like_post_#36)_set_the_meter_to_beep_when_you_touch_the_leads_together_(usually_labeled_''continuity''_testing)._Not_set_to_read_volts.
_____________________________
'03 Accord & '07 Civic
'01 Saab 9³ & '05 9²x
(in reply to HondaPhyco)
Post #: 46
RE: I need imediate help please - 6/12/2008 12:56:57 AM
PAhonda
Status: offline
I would think that it is almost impossible to have 25 volts on anything electrical in the circuit.  The maximum voltage can only be from the battery.
I want you to measure the battery voltage across the battery posts.  I put a picture of the proper setting from your volt meter.  Post the battery voltage.
The diode test I belive is the one that I have circled for continuity.  Atleast it does on my multimeter.
The resistance test will definitely work.  A closed circuit will read zero or pretty close to zero.  An open circuit should read one.
Post your results.
Thumbnail Image
Attachment (1)
< Message edited by PAhonda -- 6/12/2008 12:59:10 AM >
1995 Accord EX MT
(in reply to JimBlake)
Post #: 47
RE: I need imediate help please - 6/12/2008 5:29:51 AM
JimBlake
Status: offline
Resistance_measurement_of_an_open_circuit_will_be_OVER-RANGE_not_1.
Check_what_the_display_reads_when_the_leads_are_NOT_touching_anything.
(in reply to PAhonda)
Post #: 48
RE: I need imediate help please - 6/12/2008 5:39:10 PM
HondaPhyco
Status: offline
HondaPhyco's photo gallery
12v at battery and 11.67 at each injector wire, other side had closed circuit, guys i dont think my problem is my injectors.??
< Message edited by HondaPhyco -- 6/12/2008 5:41:55 PM >
-1996 F22 2.2L Honda Accord LX
-Street Flow Air Intake Kit
-JDM Projector lens.
20% Tints, from THE TINT SHOP!
(The number one killer of HONDA engines......leaves)
GAS-"Why pay more for less when you can pay less for more"
CAR- Ferrari :)
Post #: 49
RE: I need imediate help please - 6/12/2008 5:40:49 PM
HondaPhyco
Status: offline
i went to the dealer today they said from what i described it may be the fuel pump, the same blue and yellow wire that was stripped is the same wire that runs to the fuel pump. what do u guys think replace?
CAR- Ferrari :)
Post #: 50
RE: I need imediate help please - 6/12/2008 9:17:52 PM
PAhonda
Status: offline
You do not need to replace the fuel pump.  It is getting power and delivering fuel pressure.  The dealership is wrong.
1995 Accord EX MT
Post #: 51
RE: I need imediate help please - 6/12/2008 9:20:08 PM
HondaPhyco
Status: offline
But why is it running constantly? thats all i need to know, do you know how it feels to see your baby sit there like a log? lol
CAR- Ferrari :)
Post #: 52
RE: I need imediate help please - 6/12/2008 9:33:51 PM
PAhonda
Status: offline
I think that it could be your main fuel relay shorting out.  Just looked at the wiring diagrams.
Do the same continiuty test on the non red/blk wire.  Just unplug the main fuel relay and keep the ECU unplugged.
1995 Accord EX MT
Post #: 53
RE: I need imediate help please - 6/12/2008 9:36:44 PM
PAhonda
Status: offline
I am having trouble replying to your post.
1995 Accord EX MT
Post #: 54
RE: I need imediate help please - 6/12/2008 9:39:01 PM
HondaPhyco
Status: offline
that would be a cheaper fix, ok I tested all the wires you told me to test, i forgot which side i tested but what ever side is suppose to have 11.9 or 11.7 volts i tested, also i tested the other side and got 0. so closed circuit as you said right?
CAR- Ferrari :)
Post #: 55
RE: I need imediate help please - 6/12/2008 9:45:54 PM
PAhonda
Status: offline
That is right.  I wanted to make sure that you had all of the connectors to the ECU unplugged when you did this.
< Message edited by PAhonda -- 6/12/2008 9:46:12 PM >
1995 Accord EX MT
Post #: 56
RE: I need imediate help please - 6/12/2008 9:50:18 PM
PAhonda
Status: offline
Replying to this post is getting frustrating.  Sometimes my replies work, sometimese they won''t go through.
1995 Accord EX MT
Post #: 57
RE: I need imediate help please - 6/12/2008 9:52:00 PM
JimBlake
Status: offline
Post 49 you say the other side has closed circuit?  Closed to what?  Under what conditions?  It''''s NOT supposed to be a closed circuit.  Maybe that''''s the problem?
That wire is only supposed to be closed to ground during the brief moment when the injector is actually firing.  Not ALL THE TIME.
< Message edited by JimBlake -- 6/12/2008 9:54:29 PM >
Post #: 58
RE: I need imediate help please - 6/12/2008 9:56:28 PM
PAhonda
Status: offline
Jim,
You are correct.  That side should not be shorted to ground.  I meant that HondaPsycho was correct in that a 0 reading was a closed circuit.
I was looking at the wiring diagrams for the MFR.  The injector ground wire controlled by the the ECU is also used by the MFR to pin A23 of the ECU.
If the MFR has a short from the A23 to the A7 (pins 1 and 3), then this could explain both problems.
< Message edited by PAhonda -- 6/12/2008 9:58:27 PM >
1995 Accord EX MT
Post #: 59
RE: I need imediate help please - 6/12/2008 9:58:58 PM
HondaPhyco
Status: offline
Ok the ECU is unplugged, the fuel pump is unplugged and the key is in the II position.
CAR- Ferrari :)
Post #: 60
Honda Accord Forum >> General >> General Tech Help
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
wheelbrokera7085
sir_nasty6309
falkore245932
finch134278
00accordlx5s3815
deserthonda3575
live2rice3444
jimblake3272
19accord973171
smaglik2623
New Vendors
Sportwing
