RE: I need imediate help please
  Printable Version
Honda Accord >> General >> General Tech Help >> RE: I need imediate help please Page: <<   < prev  3 4 [5] 6 7   next >   >>
Login
RE: I need imediate help please - 6/12/2008 10:02:30 PM
HondaPhyco
Status: offline
HondaPhyco's photo gallery
So Pahonda you think its the main fuel relay.......according to the dealership and pepboys its the fuel pump, but you guys heard the whole story so i think i trust you guys more.
_____________________________
-1996 F22 2.2L Honda Accord LX
-Street Flow Air Intake Kit
-JDM Projector lens.
20% Tints, from THE TINT SHOP!
(The number one killer of HONDA engines......leaves)
GAS-"Why pay more for less when you can pay less for more"
CAR- Ferrari :)
(in reply to HondaPhyco)
Post #: 61
RE: I need imediate help please - 6/12/2008 10:02:53 PM
JimBlake
Status: offline
Then the non-red/black wire should NOT have continuity to ground.  It should be an OPEN circuit - meaning NOT connected to anything.
'03 Accord & '07 Civic
'01 Saab 9³ & '05 9²x
Post #: 62
RE: I need imediate help please - 6/12/2008 10:07:07 PM
HondaPhyco
Status: offline
that you are right my friend lol...that was my mistake.
CAR- Ferrari :)
(in reply to JimBlake)
Post #: 63
RE: I need imediate help please - 6/12/2008 10:10:41 PM
PAhonda
Status: offline
I don''t see how the fuel pump could cause your problem.  It only gets power from the main fuel relay.  If the relay keeps supplying power, then the fuel pump will continue to run.  There is no way for a failing fuel pump to keep the main fuel relay turned on.
1995 Accord EX MT
Post #: 64
RE: I need imediate help please - 6/12/2008 10:14:23 PM
HondaPhyco
Status: offline
Ok so i noticed that when i..........i tried it just to be sure..............clicked the relay into the harness it clicked once should that be the case? and also there are some dry Saunders on the circuit board.....so should i order one from ebay or pay the full price at the dealership?
CAR- Ferrari :)
(in reply to PAhonda)
Post #: 65
RE: I need imediate help please - 6/12/2008 10:20:02 PM
PAhonda
Status: offline
I''''m not sure what you mean.  Should the connector click once?
You should unplug the MFR and test for continuity on the non red/blk injector wire.  See if the circuit is open.  Post back your results.
< Message edited by PAhonda -- 6/12/2008 10:29:00 PM >
1995 Accord EX MT
Post #: 66
RE: I need imediate help please - 6/12/2008 10:22:38 PM
JimBlake
Status: offline
fragments of information sucks when we can''t post a BIG LONG post all together in one place.
So the non-red/black wire is supposed to be momentarily switched between open & ground by the ECU.  With the ECU unplugged, that wire should NOT be connected to ground.
With the ECU plugged back in, that non-red/black wire should only be connected to ground in pulses.  If it''s continuously grounded, then maybe the ECU is fried.
Post #: 67
RE: I need imediate help please - 6/12/2008 10:26:28 PM
HondaPhyco
Status: offline
the circuit is closed.
CAR- Ferrari :)
Post #: 68
RE: I need imediate help please - 6/12/2008 10:28:41 PM
JimBlake
Status: offline
Closed to GROUND?  Constantly?  NOT supposed to be.
Post #: 69
RE: I need imediate help please - 6/12/2008 10:28:57 PM
HondaPhyco
Status: offline
ok im going to test it with it plugged in in the morning, after school. I will post ASAP. I openned the ECU and didnt see any burns or maybe they arent visible.
CAR- Ferrari :)
Post #: 70
RE: I need imediate help please - 6/12/2008 10:30:55 PM
PAhonda
Status: offline
The circuit is still closed to ground even with the ECU unplugged, which means that the ECU is fine.  The short to ground is coming from somewhere else.  Wireharness or MFR.
Post back your tests with the main fuel relay unplugged.  The non red/blk wire should be an open circuit.
1995 Accord EX MT
Post #: 71
RE: I need imediate help please - 6/12/2008 10:36:37 PM
JimBlake
Status: offline
I thought the MFR was not in that side of the circuit at all.  Its only in the hot side of the injector circuit (red/black wire).  Not in the ground side of the injector circuit.
Post #: 72
RE: I need imediate help please - 6/12/2008 10:38:43 PM
HondaPhyco
Status: offline
Ok guys im going to bed, since Jim is confused about what you said PAhonda you guys work it out and ill check it tommorow. other than testing the non rd and blk side. Something else to look for or test.
CAR- Ferrari :)
Post #: 73
RE: I need imediate help please - 6/12/2008 10:41:58 PM
JimBlake
Status: offline
If the site doesnt accept posts tomorrow, email me.  I can post a summary for posterity later.
Post #: 74
RE: I need imediate help please - 6/12/2008 11:08:54 PM
PAhonda
Status: offline
I can''t write a long post.  Basically the MFR grounds constantly at ECU pin A23 and A23 is the ground for the injectors.
1995 Accord EX MT
Post #: 75
Honda Accord Forum >> General >> General Tech Help
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
wheelbrokera7085
sir_nasty6309
falkore245932
finch134278
00accordlx5s3815
deserthonda3575
live2rice3444
jimblake3272
19accord973171
smaglik2623
New Vendors
Sportwing
