RE: I need imediate help please
  Printable Version
Honda Accord Forums >> General >> General Tech Help >> RE: I need imediate help please Page: <<   < prev  3 4 5 [6] 7   next >   >>
Login
RE: I need imediate help please - 6/13/2008 5:40:50 AM
JimBlake
Status: offline
For injector ground-leg to be closed all the time means MFR *AND* ECU have to close.
MFR supposed to be closed constant (key on).
ECU only supposed to pulse closed.
_____________________________
'03 Accord & '07 Civic
'01 Saab 9³ & '05 9²x
(in reply to PAhonda)
Post #: 76
RE: I need imediate help please - 6/13/2008 5:56:56 AM
JimBlake
Status: offline
Do you have a 1996 wiring drawing?  OBD-2 has different pin-out than your 1995.
I know that 1998 A23 isnt injector ground.
(in reply to JimBlake)
Post #: 77
RE: I need imediate help please - 6/13/2008 10:37:46 AM
HondaPhyco
Status: offline
HondaPhyco's photo gallery
I do not have the wireing diagram, im only 18 yrs old, and im in my first year of physics, lol. I will try to read it though. But i did test the wires on the injectors the non blk and red side is getting no voltage and the other side has continuity of about 11.2 now...battery is dying. was 11.8
-1996 F22 2.2L Honda Accord LX
-Street Flow Air Intake Kit
-JDM Projector lens.
20% Tints, from THE TINT SHOP!
(The number one killer of HONDA engines......leaves)
GAS-"Why pay more for less when you can pay less for more"
CAR- Ferrari :)
Post #: 78
RE: I need imediate help please - 6/13/2008 11:30:17 AM
PAhonda
Status: offline
I just looked at a 96 wiring diagram.  The pinout is different, but the overall setup is the same.  A10 is the ground for the Injectors.
1995 Accord EX MT
(in reply to HondaPhyco)
Post #: 79
RE: I need imediate help please - 6/13/2008 11:35:41 AM
JimBlake
Status: offline
LOL Im not raggin about your age.  Question about wiring drawing was mostly for PA because pin A23.
Red/black wires should have battery VOLTAGE.  Not measuring continuity there.
Other wire is measured for continuity, not voltage.
Reply to my email so I can send you more detail.
Post #: 80
RE: I need imediate help please - 6/13/2008 11:58:51 AM
HondaPhyco
Status: offline
Ok jim i sent the email
Got it, THANKS.
also i tested the injectors time and time again, they are functioning right according to the readings.
< Message edited by JimBlake -- 6/13/2008 12:28:59 PM >
CAR- Ferrari :)
Post #: 81
RE: I need imediate help please - 6/13/2008 3:15:51 PM
deserthonda
Status: offline
On an earlier statement you said  that the fuel pump runs all the time......care to give more info ??
does it run with the key off  ???
does it run with the key on   ??? ( no cranking )
No Year No Model in Your signature
No Help from me
Take a look in the DIY section before asking for help
Always Diagnose First,,, Before Replacing Parts
Post #: 82
RE: I need imediate help please - 6/13/2008 7:32:43 PM
HondaPhyco
Status: offline
its running with the key on and when key is off it shuts off.
CAR- Ferrari :)
(in reply to deserthonda)
Post #: 83
RE: I need imediate help please - 6/14/2008 9:23:22 AM
HondaPhyco
Status: offline
Ok jim i went out and tested the injectors again.....i see what you were saying now, they are all being grounded out. I put the pin on one of them and it opened the injector they all opened the injectors. it was just a test to see if it was all or just two. But one side has voltage of about 11.6 and other side has continuity of about 068(non red/blk side) with key on (all the time). but until i can get those injectors to stop grounding out i cant try and start the car just yet.
CAR- Ferrari :)
Post #: 84
RE: I need imediate help please - 6/14/2008 9:24:39 AM
HondaPhyco
Status: offline
by the way arent the injectors grounded by the ECU meaning that the ECU is malfunctioning...dont forget about solid CEL and no code, tried to jumper.
CAR- Ferrari :)
Post #: 85
RE: I need imediate help please - 6/14/2008 11:52:12 AM
JimBlake
Status: offline
Injectors being fired by bad ECU or wiring short.  Need to figure out which.
If all is OK, CEL supposed to be on solid when jumpered.
Post #: 86
RE: I need imediate help please - 6/14/2008 12:17:24 PM
HondaPhyco
Status: offline
I think the ECU is grounding the injectors and is not sending that signal to cut the ground, Pa said in a earlier post the Fuel pump is controlled by the relay?
< Message edited by HondaPhyco -- 6/14/2008 12:25:12 PM >
CAR- Ferrari :)
Post #: 87
RE: I need imediate help please - 6/16/2008 5:34:14 AM
JimBlake
Status: offline
Pump is switched by the main relay, but the ECU tells the main relay what to do.  If you get a new ECU for the injectors, lets see what happens with the pump.
Post #: 88
RE: I need imediate help please - 6/21/2008 5:08:28 PM
PAhonda
Status: offline
I was curious about this thread, did the new ECU fix your problem?
1995 Accord EX MT
Post #: 89
RE: I need imediate help please - 6/23/2008 6:57:43 AM
JimBlake
Status: offline
Im curious too.  Last I heard Phyco was gonna buy an ECU.
Post #: 90
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
wheelbrokera7085
sir_nasty6309
falkore245932
finch134278
00accordlx5s3815
deserthonda3575
live2rice3444
jimblake3272
19accord973171
smaglik2623
New Vendors
Sportwing
