RE: pics of yourself
  Printable Version
Honda Accord >> General >> Off Topic >> RE: pics of yourself Page: <<   < prev  1 2 [3] 4 5   next >   >>
Login
RE: pics of yourself - 6/26/2008 11:46:30 AM
finch13
Status: offline
Not much... between 1 and 2 tons...
_____________________________
USE ME TO SEARCH HAF
PWOTY 2008!
(in reply to KevinAccord)
Post #: 31
RE: pics of yourself - 6/26/2008 1:30:06 PM
falkore24
Status: offline
falkore24's photo gallery
quote:
ORIGINAL: finch13
The ammonia refrigeration system is driven by 3 compressors so it does get a fair bit of help on the chemistry side of things. The warehouse is roughly 150,000 sq. ft., completely refirigereated from 40 deg. down to -10 deg.
They typically work on liquid phase pressure boosting pumps then have manual throttling valves to deal with the phase change.  It sounds like you have a double accumulator system with closed circuit evaporative cooling.  I did some work on a similar system for Winco Foods ..... I had to figure out the weight of the ammonia in the system to figure out base and emergency ventillation rates .... it came out to about 55,000 lbs of ammonia after a week of calculations.
quote:
ORIGINAL: KevinAccord
From pics to A/C in a few hours!!!!! Anyways... it sound cool what you do Falk, U get paid well? hope so! sound like tons of hard work. I need an a/c for my appartment. it''''s like 50ft by 65ft. How many ton''''s will I need?
I like what I do mainly because it''s not the every day typical design work that I could do in my sleep.  A general rule of thumb for residential cooling is 500 sq.ft. per ton, but if you could draw a picture of the apartment with room sizes, window sizes, ceiling height, North orientation and appliances, I could give you an accurate calculation of what you need.  In PR, I''d expect closer to 350-400 sq.ft. per ton due to the weather.
2006 Scion TC (ZPI-18G pending)
2000 V6-AT (RIP 3G)
Temp Search thanks to Finch13
Post #: 32
RE: pics of yourself - 6/26/2008 3:42:22 PM
nafango2
Status: offline
...why is it that you measure air conditioning in tons?
seems strange...
96 Accord LX 4cyl. 4dr AT w/o vtec (F22B2)
Security System / Keyless entry
(in reply to falkore24)
Post #: 33
RE: pics of yourself - 6/26/2008 6:17:12 PM
j_man_honda
Status: offline
j_man_honda's photo gallery
Wow this thread has been jacked!!!
1999 Honda Accord "EX"(SOLD)
1996 Nissan 240sx "SE"
(in reply to nafango2)
Post #: 34
RE: pics of yourself - 6/27/2008 6:37:04 AM
KevinAccord
Status: offline
massively! hey ppl... keep the pics comming!
J_Man: i need my cooling system info dude! LOL
2000 Accord LX i4 Turbo AT
18" Konig Unknown Rims
MSD 6AL
Gold Line Suspension
Apexi Neo
Few other Mods...
Mini Cooper 2006 MT
HID's
17" Rims
Premium Package
Sport Suspension
Short Shifter
Panoramic Sunroof
Stock Engine (For
(in reply to j_man_honda)
Post #: 35
RE: pics of yourself - 6/27/2008 7:16:17 AM
finch13
Status: offline
It has to do with cooling 1 ton of water and the energy required to do it...
PWOTY 2008!
Post #: 36
RE: pics of yourself - 6/27/2008 7:20:23 AM
finch13
Status: offline
quote:
Wow! A ton of cooling, that must be a lot. Well, it is...it''s 12,000 Btu''s (British thermal units) per hour of heat being moved out of the space being cooled. Most residential air conditioning systems are in the range of 1 to 5 tons. But where did the term come from? Early refrigeration came about due to the desire to make ice, spawned primarily by the brewing industry (cheers). Prior to mechanical refrigeration, the only way to produce cool temperatures was by removing heat with melting ice. As ice melts, it absorbs a "heat of fusion", an amount equal to 144Btu/lb. Thus, a TON of ice, melting in one day would absorb 288,000 Btu''s of heat or 12,000 Btu''s every hour for 24 hours. A ton of ice is a cube a little over 3'' on each side. Imagine your 3 ton system on your house replaced by a column of ice 3''x3''x9''tall being melted each day. Of course, this is not quite true since your 3-ton system only runs at full capacity a fraction of the day but it''s an interesting visualization. Early refrigeration systems were sized in comparison to the equivalent amount of ice needed prior to their advent; ice which was harvested from rivers in winter and stored in large ice houses for use during the summer months.
PWOTY 2008!
(in reply to finch13)
Post #: 37
RE: pics of yourself - 6/27/2008 7:57:21 AM
falkore24
Status: offline
^^^   I think the units in that post are intended to be feet.  For some reason HAF won''t allow a single tick mark.
2000 V6-AT (RIP 3G)
Post #: 38
RE: pics of yourself - 6/30/2008 8:43:52 AM
slammed97
Status: offline
Looks like mechanical engineering killed this thread.
Does anyone else have pics and details about themselves?
-97 Accord LX:air ride,18''''s,CAI,Catback,Pioneer HU and spkrs,mmats amp
-05 Accord EX-L:stock,wife''''s car
-99 Wrangler:longarm,35''''s,9" front-detroit,8.8" rear-arb,4.56,etc
-67 Cougar:289,8.8,my 1st car- project
-05 Mustang GT vert:loaded,*
Post #: 39
RE: pics of yourself - 6/30/2008 12:26:31 PM
falkore24
Status: offline
LOL .... well I see 7 pictures of different people .... and mine like 4 or 5 times, so it''s not my fault!!!!  Kevin, PM me if you need help with your AC.
2000 V6-AT (RIP 3G)
(in reply to slammed97)
Post #: 40
RE: pics of yourself - 7/1/2008 10:25:46 AM
KevinAccord
Status: offline
ok... but first i need to know if it''s true that a console (let''s say 12k btu) spends less energy (ohms) than the one you  put on the window. In my house (not the apartment for college) I have a room w/ out a/c... it''s like 12ft by 15ft plus a small bath...
MSD 6AL
Apexi Neo
Few other Mods...
Mini Cooper 2006 MT
HID's
17" Rims
Premium Package
Sport Suspension
Short Shifter
Panoramic Sunroof
Stock Engine (For
Post #: 41
RE: pics of yourself - 7/1/2008 11:37:50 AM
nafango2
Status: offline
this is me at the beach:
Post #: 42
RE: pics of yourself - 7/1/2008 11:49:30 AM
ford
Status: offline
quote:
ORIGINAL: nafango2
LOL!! WTF DUDE!!haha...
anyways... i''ll post my pic later...
1994 Honda Accord Ex Leather
-F22B1 I4 SOHC VTEC
-Automatic Transmission
-Ebay Cat Back Exhaust Syst
Post #: 43
RE: pics of yourself - 7/1/2008 12:19:24 PM
falkore24
Status: offline
ok... but first i need to know if it''''s true that a console (let''''s say 12k btu) spends less energy (ohms) than the one you  put on the window. In my house (not the apartment for college) I have a room w/ out a/c... it''''s like 12ft by 15ft plus a small bath...
The shape of the unit doesn''t really matter.  Look at the EER and SEER numbers to compare energy usage.  The higher, the better.  Window units tend to be cheaper construction than other types resulting in low EER and SEER values.
FYI - Ohms is resistance, power is energy (kW).
2000 V6-AT (RIP 3G)
Post #: 44
RE: pics of yourself - 7/1/2008 4:34:46 PM
03Sleeper
Status: offline
03Sleeper's photo gallery
wow! i didnt know brad pitt was an accord enthusiast! [/sarcasm]
2003 Accord LX Sedan I4| 5AT 107000
Injen SRI w/ AEM Dryflow| DCSports Ceramic Headers| DENSO IK20 Sparks| CF Front Strut Bar| Pioneer TSG950M 6x9s| Alpine SPS17C2 6.5"| C-Tek Slotted/Drilled Rotors | Progress 24mm Rear Sway Bar
Post #: 45
Honda Accord Forum >> General >> Off Topic
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
wheelbrokera7083
sir_nasty6309
falkore245932
finch134278
00accordlx5s3815
deserthonda3575
live2rice3444
jimblake3272
19accord973171
smaglik2623
New Vendors
Sportwing
