RE: Hydrolock Scare!!!
  Printable Version
Honda Accord Forum >> Your Ride >> Engine & Internal >> RE: Hydrolock Scare!!! Page: <<   < prev  1 [2]
Login
RE: Hydrolock Scare!!! - 7/11/2008 9:17:49 AM
sofireguy
Status: offline
I cant remember where to jumper for ECU readouts or how to restart the ECU. Autozone doesnt have the right reader for my car. and what kind of sensor could i have blown?
(in reply to sofireguy)
Post #: 16
RE: Hydrolock Scare!!! - 7/11/2008 9:34:16 AM
sofireguy
Status: offline
Ok I remembered. I jumpered the diagnostic plug and got this.  Engine: Long-Short-Short & ABS: Long-Short-Short
Post #: 17
RE: Hydrolock Scare!!! - 7/11/2008 9:44:11 AM
falkore24
Status: offline
falkore24's photo gallery
OK, I think that''s the no code sequence ..... also tells us that the CEL light works.  The easiest way to reset the ecu is to pull the battery + lead and touch it to the - terminal to discharge any capacitors that may be in the system...... leave it for 10-15 minutes and plug the battery back in.
_____________________________
2006 Scion TC (ZPI-18G pending)
2000 V6-AT (RIP 3G)
Temp Search thanks to Finch13
Post #: 18
RE: Hydrolock Scare!!! - 7/11/2008 9:51:03 AM
sofireguy
Status: offline
What is the code reading though?? I looked and the long one is telling there is a code or break right? Then the short ones are the readings right? So i looked up the codes i think here: http://www.troublecodes.net/honda/
I think it''''s MAP sensor ** ??? That would make sense since water got into intake ? OR is it the Faulty ECU one *-**???
Post #: 19
RE: Hydrolock Scare!!! - 7/11/2008 12:39:02 PM
JimBlake
Status: offline
ECU code 12 = EGR
Good ECU with no stored codes shines the CEL on solid.
Failed ECU supposedly shows CEL but doesnt turn it on at all when the connector is jumpered.
ABS codes...
(this is for the older system WITH ABS fluid reservoir)
First long flash & long pause arent part of a code.
Short flashes for 1st digit.
short-ish pause.
Short flashes for 2nd digit.
long pause.
Next code (or repeat 1st code).
< Message edited by JimBlake -- 7/14/2008 10:47:54 AM >
'03 Accord & '07 Civic
'01 Saab 9³ & '05 9²x
Post #: 20
RE: Hydrolock Scare!!! - 7/12/2008 4:55:59 PM
sofireguy
Status: offline
Alright, I flushed out with Sea Foam and Drygas, it runs smoother. But I still have a limited RPM range of 5500RPM when i rev it. I just feels like it rev limits and runs rough.
(in reply to JimBlake)
Post #: 21
RE: Hydrolock Scare!!! - 7/12/2008 4:59:44 PM
sofireguy
Status: offline
Is there anything else that would cause a Limited RPM range? Like a fouled spark plug or distributor cap? Also, the EGR vac hose was just unplugged for some reason, i probably bumped it one time.
Post #: 22
RE: Hydrolock Scare!!! - 7/12/2008 5:03:45 PM
sofireguy
Status: offline
Or water in the crankcase??? I just (forgot to in the first place) checked the MILKY dipstick. could that be it?
Post #: 23
RE: Hydrolock Scare!!! - 7/12/2008 5:35:01 PM
sofireguy
Status: offline
Yeah.. I feel retarded now for reving my engine without checking the oil...
Post #: 24
RE: Hydrolock Scare!!! - 7/13/2008 3:30:14 AM
YeuEmMaiMai
Status: offline
engine will NOT rev to redline in neutral.
Jesus is Salvation
White 2002 Acura CL type S. 68K and change
Criminals thrive upon the intolerence of society''s understanding.....and political correctness
Post #: 25
RE: Hydrolock Scare!!! - 7/13/2008 9:13:46 AM
03Sleeper
Status: offline
03Sleeper's photo gallery
^ Ditto.
Shoulda went SRI :P
2003 Accord LX Sedan I4| 5AT 107000
Injen SRI w/ AEM Dryflow| DCSports Ceramic Headers| DENSO IK20 Sparks| CF Front Strut Bar| Pioneer TSG950M 6x9s| Alpine SPS17C2 6.5"| C-Tek Slotted/Drilled Rotors | Progress 24mm Rear Sway Bar
(in reply to YeuEmMaiMai)
Post #: 26
RE: Hydrolock Scare!!! - 7/14/2008 9:16:15 AM
KevinAccord
Status: offline
guess that solves the eternal issue of whether to get a CAI or a SRI! LOL
2000 Accord LX i4 Turbo AT
18" Konig Unknown Rims
MSD 6AL
Gold Line Suspension
Apexi Neo
Few other Mods...
Mini Cooper 2006 MT
HID's
17" Rims
Premium Package
Sport Suspension
Short Shifter
Panoramic Sunroof
Stock Engine (For
(in reply to 03Sleeper)
Post #: 27
RE: Hydrolock Scare!!! - 7/14/2008 9:53:10 AM
falkore24
Status: offline
Jim:  Thanks for the code info.
Water in the oil and low oil?  Have you checked your cylinder compression to see if you have a blown head gasket?
2000 V6-AT (RIP 3G)
(in reply to KevinAccord)
Post #: 28
RE: Hydrolock Scare!!! - 7/14/2008 10:50:04 AM
JimBlake
Status: offline
quote:
ORIGINAL: falkore24
check the disclaimer I just added.
quote:
ORIGINAL: falkore24
GOOD idea to check.
(in reply to falkore24)
Post #: 29
Honda Accord >> Your Ride >> Engine & Internal
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
wheelbrokera7085
sir_nasty6309
falkore245932
finch134278
00accordlx5s3815
deserthonda3575
live2rice3444
jimblake3272
19accord973171
smaglik2623
New Vendors
Sportwing
