RE: change your tranny fluid
Login | |
RE: change your tranny fluid - 4/10/2006 1:31:18 AM
nixalot
I'm sorry deserthonda, I meant the procedure... it's as simple as pull the plug, drain, and then refill through the dipstick hole?
RE: change your tranny fluid - 4/10/2006 3:03:24 AM
lightshow
there is actually a bolt that you unscrew on the top of the tranny that is easier to fill the tranny with, but you can fill it through the dipstick. but yes it is just that easy. drain, then fill.....youll be all set
RE: change your tranny fluid - 4/10/2006 1:29:49 PM
sir_nasty
Also to make your life easier if you get one of those screw on caps that has a flexible hose that comes off it (like $2-$3 from an auto store) it will go over the top of your tranny fluid bottles and then you can pour it in without the mess.... if you're really impatient then after you start the fluid flowing (if you use that tube thing I was talking about...) then punch a hole in the bottom of it with a knife or something to allow more airflow.... (think beer bong principal...)
RE: change your tranny fluid - 4/10/2006 2:02:21 PM
brad6841
Would this be the same for a 2002 V6 Auto? Is it also true there is no filter? mbo1895, About how many quarts do you need to perfom the flush? 5, 6, more?
RE: change your tranny fluid - 4/10/2006 2:43:14 PM
lightshow
there is no filter that you "change"
RE: change your tranny fluid - 5/10/2006 8:50:48 PM
longhornjohn
In regards to flush and fill-----I think the only way you can drain the converter is if it has a drain plug or at least American trannies are that way. If I am wrong about Honda then please let me know.
RE: change your tranny fluid - 5/10/2006 9:07:29 PM
longhornjohn
Does anyone know if Wix makes an inline filter to install in the line that goes to the radiator cooler? Might be a good way to filter out the wear particles of the bands, clutches, etc.
RE: change your tranny fluid - 12/17/2006 9:45:25 PM
adamc44
Joined: 12/12/2006 From: West Portsmouth Ohio Status: offline
so if i was going to change my tranny fluid next week on my 94lx all i have to do is remove the bolt on the trans by the passenger side, let it drain, then refill with atf-z1? there is no filter i would fool with at all? how many quarts is required? any help is appreciated thanks adam.
RE: change your tranny fluid - 12/17/2006 10:08:13 PM
drummer1279
Joined: 8/4/2006 From: greenville, south carolina Status: offline
yes it is that easy, and you dont need anymore than 3 quarts.
_____________________________
Do not taunt happy fun ball... 1992 Accord LX Automatic
RE: change your tranny fluid - 12/17/2006 10:13:18 PM
drummer1279
and no filter, the filter is internal
RE: change your tranny fluid - 12/17/2006 11:04:28 PM
adamc44
ok thanks drummer
RE: change your tranny fluid - 12/18/2006 4:08:11 PM
drummer1279
no prob
RE: change your tranny fluid - 12/18/2006 5:33:14 PM
deserthonda
you can easily install an outside filter if you like,,,,,,,,,Honda reman trannies come with an external filter ..... Very easy to hook 1 up...... cut the return cooler line and istall the filter in the lines , make sure to have the flow of fluid going the proper way
No Year No Model in Your signature No Help from me Take a look in the DIY section before asking for help Always Diagnose First,,, Before Replacing Parts
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Honda Accord Prices
Advertising Info
Contact Us |
Advertising |
Automotive Links |
Archive |
About Us |
Honda Accord Links |
Legal |
Privacy Policy |
© Honda Accord Forum.com
