RE: Car Does Not Accelerate
Login | |
RE: Car Does Not Accelerate - 11/12/2008 6:42:57 AM
abhijitgp
I am changing the spark plugs this weekend, and will post the results. Is it necessary to change the wires as well? Also, another thing that I forgot to mention was that the car gives terrible mileage, approx. 18 MPH or less within city. Is it associated with the OBD II code P0240: Catalyst System Efficiency Below Threshold (Bank 1)? Thanks
_____________________________
1994 Honda Accord EX (5-speed Manual) (>195K miles)
RE: Car Does Not Accelerate - 11/12/2008 6:52:50 AM
falkore24
quote:
ORIGINAL: JimBlake quote:
ORIGINAL: TexasHonda If rpm increases significantly w/o acceleration or increase in speed, the transmission has a problem. From your description, the transmission is slipping badly. good luck YES. After re-reading the original post, I gotta agree with this. Bad plugs or a plugged cat would cause the engine to lose power. In that case it WOULD NOT rev high. Revving high indicates the engine is making the power, but the tranny cant deliver it to the axles. With a manual tranny, that means you simply need a new clutch. With an automatic, ??? If it was a 98-02 Honda automatic, the tranny would be near-death. Slipping isn''t the 6th gen design flaw. Slipping means the frictions are shot. Still means that the tranny needs to be torn down or replaced, but friction replacement is cheaper than buying a new tranny in most cases. L10 and Dr. Evil can upgrade the tranny at the same time to lessen the chance of true tranny death, but at a price.
2006 Scion TC (ZPI-18G pending) 2000 V6-AT (RIP 3G) Temp Search thanks to Finch13
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Honda Accord Prices
Advertising Info
Contact Us |
Advertising |
Automotive Links |
Archive |
About Us |
Honda Accord Links |
Legal |
Privacy Policy |
© Honda Accord Forum.com
