RE: my accord is slowwww, help
  Printable Version
Honda Accord >> General >> General Tech Help >> RE: my accord is slowwww, help Page: <<   < prev  1 [2]
Login
RE: my accord is slowwww, help - 11/2/2008 9:55:30 PM
clutch811
Status: offline
with the mileage and all when was your last tune up? your mpg seems off and considering your power reduction i would say. new ignition, sparks plugs, cap, rotor, wires. then also consider your air filter. when was your last oil change? these being bad can really kill performance and mileage. also do you notice any rough idling with the car?
_____________________________
1994 Accord LX lowered
AEM short ram intake
megan header
Ractive cat back
(in reply to yeding)
Post #: 16
RE: my accord is slowwww, help - 11/3/2008 6:23:29 AM
falkore24
Status: offline
falkore24's photo gallery
If you really want to make it significantly faster, I can help you locate a really nice nitrous setup.
2006 Scion TC (ZPI-18G pending)
2000 V6-AT (RIP 3G)
Temp Search thanks to Finch13
(in reply to clutch811)
Post #: 17
RE: my accord is slowwww, help - 11/3/2008 7:06:05 AM
Vipers4Life
Status: offline
Vipers4Life's photo gallery
quote:
ORIGINAL: yeding
hi,Vipers4Life:
do u mind to tell me how it feel like when it''''s slipping...... mine feels funny sometime when go downhill or uphill.. it''''s like lost power for a second and then everything is fine. but I paid special attention to the rpm when it happened, rpm doest change. so I really dont know waht is th deal and tried to convince myself that''''s how Honda rolls..........
For me what it does is when I first start driving it when it goes to shift into 2nd it will slip into neutral for like a second then go into 2nd gear. So usually when the tranny slips it generally goes into neutral. I''m sure if you search up tranny problems on here you''ll find a lot of them.
99 Accord LX Sedan I4 Auto F23A4
AEM SRI
Post #: 18
RE: my accord is slowwww, help - 11/3/2008 11:07:01 AM
finch13
Status: offline
quote:
ORIGINAL: falkore24
^ He''s a hustler, be careful!
just kidding. Great kit for the $$$.
I think we just might be dealing with the fact that Honda''s are not Formula 1 cars... at least not the ones us consumers can purchase.
USE ME TO SEARCH HAF
PWOTY 2008!
(in reply to falkore24)
Post #: 19
RE: my accord is slowwww, help - 11/3/2008 2:14:55 PM
falkore24
Status: offline
A lot of people are making posts like they intend to augment at 100HP or above.  At this level, the gas part of the wet system can pool, throwing off the A/F majorly ..... leading to engine damage or death.  Direct port is mandatory for this kind of shot.  Direct port is more expensive than a single fogger setup.
My buddy actually would like to spray 80HP on his S2000, but needs the money.  If it''s still around when he gets back on his feet, that''ll be 1 super fast car!  It already redlines at 9200!!!
2000 V6-AT (RIP 3G)
(in reply to finch13)
Post #: 20
RE: my accord is slowwww, help - 11/3/2008 8:43:18 PM
yeding
Status: offline
thx guys for all ur input here.
I only had this car for 3 monthes, and my last oil change is last month. But I do found my air filter not being the cleanest. so gonna change it out.
I''m not really worried too much about the MPG here. Just the fact it''s slow makes me wondering if my 1st gear is slipping a little bit. I think transmission being slipping can cause bad MPG and poor performance too.
when u guys said it slip into neutral. what that feel like? can u actually see the gear indicator light up "N"? or just the rpm going up like crazy?  thx
Post #: 21
RE: my accord is slowwww, help - 11/4/2008 5:11:23 AM
falkore24
Status: offline
There''s about a half second between gears that you can hear that there is no gear engaged, almost like double-clutching a manual.  The auto tranny won''t shoot up in rpms like a manual would when you floor the clutch because of the torque convertors -fluid linkage- maintaining a bit of load in neutral.  The shift indicator doesn''t change.
2000 V6-AT (RIP 3G)
Post #: 22
RE: my accord is slowwww, help - 11/4/2008 7:09:42 PM
yeding
Status: offline
quote:
ORIGINAL: falkore24
There''''s about a half second between gears that you can hear that there is no gear engaged, almost like double-clutching a manual.  The auto tranny won''''t shoot up in rpms like a manual would when you floor the clutch because of the torque convertors -fluid linkage- maintaining a bit of load in neutral.  The shift indicator doesn''''t change.
thx, but I read from somewhere else that when the tranny is slipping, the rpm will rev up to coupe thousand but the car wont accelerate. mine is just accelerate slowly and will pick up when the rpm get up to around 2000. and when i press gas hard, i will feel it hesitate a little bit when change from 1st to 2nd, but it''s not so bad, I think my other car does that too.
so is there any easy way to test if tranny is slipping?
sorry if it''s a really dumb question? since I have never drive a manual, so i really dont know how "double-clutching" feels like ?  thx  a lot
Post #: 23
RE: my accord is slowwww, help - 11/4/2008 9:15:25 PM
cjdm98
Status: offline
cjdm98's photo gallery
You feel a jerking sensation in the tranny.its pretty noticeable.
>>Click here to see my Accord<<
Post #: 24
RE: my accord is slowwww, help - 11/5/2008 6:53:55 AM
falkore24
Status: offline
quote:
ORIGINAL: yeding
quote:
ORIGINAL: falkore24
There''''''''''''''''''''''''''''''''s about a half second between gears that you can hear that there is no gear engaged, almost like double-clutching a manual.  The auto tranny won''''''''''''''''''''''''''''''''t shoot up in rpms like a manual would when you floor the clutch because of the torque convertors -fluid linkage- maintaining a bit of load in neutral.  The shift indicator doesn''''''''''''''''''''''''''''''''t change.
thx, but I read from somewhere else that when the tranny is slipping, the rpm will rev up to coupe thousand but the car wont accelerate. mine is just accelerate slowly and will pick up when the rpm get up to around 2000. and when i press gas hard, i will feel it hesitate a little bit when change from 1st to 2nd, but it''''''''''''''''s not so bad, I think my other car does that too.
sorry if it''''''''''''''''s a really dumb question? since I have never drive a manual, so i really dont know how "double-clutching" feels like ?  thx  a lot
I''''''''m talking about the neutral gap between gears on a gear change, not the tranny slipping.  If the tranny is slipping, the rpms will go up, but the power output won''''''''t.
EDIT:  Also, I wasn''''t talking about how it feels to double-clutch or rev in neutral.  I only meant the tranny action of going from one gear, sitting in neutral for a split second and then shifting into the next gear.
cjdm:  If done right, any kind of shift can be silky smooth.  I''m pretty good at normal up and downshifting at this point.  Pretty good at double-clutching and fast shifting too ...... I''m getting better at the heal-toe, braking downshift, but not good enough to do it on a full speed turn.   IMO, I''ll be ready for Skip Barber Stage I in another 2-3 months.
< Message edited by falkore24 -- 11/5/2008 7:00:48 AM >
Post #: 25
RE: my accord is slowwww, help - 11/5/2008 9:33:29 AM
Vipers4Life
Status: offline
LOL I guess I''ll get a video of my tranny slipping so you will know what its like.
AEM SRI
Post #: 26
Honda Accord Forums >> General >> General Tech Help
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
wheelbrokera7085
sir_nasty6309
falkore245950
finch134329
00accordlx5s3818
deserthonda3575
live2rice3472
jimblake3290
19accord973171
smaglik2623
New Vendors
Sportwing
