RE: 04 Accord Help
  Printable Version
Honda Accord Forum >> General >> Off Topic >> RE: 04 Accord Help Page: <<   < prev  1 [2]
Login
RE: 04 Accord Help - 11/3/2008 4:41:42 PM
finch13
Status: offline
I told you all those chips are BS, the only real way to chip the car is converting it to OBDI and tuning it with Crome or buy Hondata K-Pro, but neither of which will benefit you. Yes, having a higher revlimiter usually does mean more power and pushing a gear to a higher speed, but only on engine capable of turning that high. Crotch rocket engines can spin up to 16,000 rpms easily, but why does my Honda cut out at 6,250? Engine design. You can''t just turn up the dial.
If you go turbo or n/a or something, sure I''ll recommned you get Hondata, but you have a stock car, you can''t really just get more power out of it...
_____________________________
USE ME TO SEARCH HAF
PWOTY 2008!
(in reply to game0over)
Post #: 16
RE: 04 Accord Help - 11/3/2008 4:45:24 PM
game0over
Status: offline
Ok man.. I see what you mean.. Sorry I''m a noob to this kind of stuff :)
Thanks for the quick response and awesome advices
I really appreciate everything
(in reply to finch13)
Post #: 17
RE: 04 Accord Help - 11/3/2008 4:46:43 PM
finch13
Status: offline
No problem, we were all noobs at one point.
PWOTY 2008!
Post #: 18
RE: 04 Accord Help - 11/3/2008 4:56:03 PM
live2rice
Status: online
live2rice's photo gallery
Finch you cant run Hondata with a A/T, so that rules that out.  And as for the upped rev limiter, most cars dont make power over redline anyways, and its really just asking for catastrophic engine failure.
quote:
ORIGINAL: hondadude
I would not put a fram filter on a lawnmower engine...
1997 Fiji Blue Pearl CD7
1995 Sage Green Metallic CD5
Post #: 19
RE: 04 Accord Help - 11/4/2008 5:12:38 AM
JimBlake
Status: offline
They pick the redline based mostly on when the engine runs out of breath.  You need a new cam or other internal work to let it breath at higher RPM.  Gotta strengthen & balance stuff better too, if you want to go much higher.
'03 Accord & '07 Civic
'01 Saab 9³ & '05 9²x
Post #: 20
RE: 04 Accord Help - 11/6/2008 7:22:46 PM
game0over
Status: offline
Ok thanks guys :)
(in reply to JimBlake)
Post #: 21
RE: 04 Accord Help - 11/7/2008 4:26:52 AM
falkore24
Status: offline
falkore24's photo gallery
Direct Port Nitrous
^^ here''s a link to the nitrous sale thread.  I''m actually not sure of what pills are in the kit ..... I''ll have to look, but I''d expect 75 and 100 to be in there, probably a third set too, but I''ll look and update the thread.
As far as raising the redline, don''t do it!  You''ve already stated that you don''t have $$$$ to spend on this project and to raise the redline safely, you have to upgrade your valve springs and retainers, minimum.  Lighter valves, new seats and guides are recommended to do at the same time and this will cost about $1500 just for the head work ....... mine''s going to wind up costing about that and I''m doing the majority of the assembly and disassembly myself.
I also have a V-AFC2 for sale, but have been too lazy and busy to put a thread up for it ..... I actually think I had one at some point, but I can''t find it.  This would allow you to play with VTEC engagement and get a dyno tune.
Poly engine and tranny mounts will allow you to take off harder without wheel hop.  Also, spinning the tires is much less dangerous to the car with them in place.
Lastly, power launching will shave off about 0.3-0.4 seconds if done right, but if you hold the stall rpm of the torque converter too long while braking, you will heat up the tranny and could cause problems.
2006 Scion TC (ZPI-18G pending)
2000 V6-AT (RIP 3G)
Temp Search thanks to Finch13
Post #: 22
Honda Accord >> General >> Off Topic
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
wheelbrokera7085
sir_nasty6309
falkore245950
finch134329
00accordlx5s3818
deserthonda3575
live2rice3472
jimblake3290
19accord973171
smaglik2623
New Vendors
Sportwing
